Stock throttle body enlargement
Old 01-19-2007, 03:27 PM
MR.KIDD
MR.KIDD's Avatar
Default Stock throttle body enlargement
Have any of you tried to enlarge the stock throttle body by boring it or is it not possible?
Old 01-19-2007, 04:09 PM
95BlueBomber
95BlueBomber's Avatar
I polished mine and I believe the issue with honing it very much is that its not solid. There is a gap between the outside casting and the inside I believe. When you polish it, it does turn out to be somewhat larger but of course in the middle its the same size. You would have to replace the blade in the throttlebody if it was to be honed.
Old 01-19-2007, 06:00 PM
MR.KIDD
MR.KIDD's Avatar
I was wondering if it was possible to put a larger blade in it and if so how much larger.
Old 01-19-2007, 07:22 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NoooooOOOOOOOoooo!!!! Its way too thin and you will destroy it! If you arerunning 400 RWHp or less, you do not need to worry about it! if you have 400 + RWHP get an aftermarket intake and a LS2 TB from ValveGod
BC
Old 01-19-2007, 11:25 PM
MR.KIDD
MR.KIDD's Avatar
BC
Thanks for the info I just purchased the LS2TB
To Stock throttle body enlargement
Quick Reply: Stock throttle body enlargement
