Which Kumho Tires???
Trying to decide between Kumho ECSTA MX's, XRP's or ASX's. To be used for normal and spirited driving - no racing. Would like the Quietest one of the three (???) or the runflats if they are pretty quiet. I know the ASX's have the best treadwear but that is not the most important factor (quiet is). Want to be able to corner well in most conditions too.
Can anyone offer their experience between 2 or 3 models above??
I've had the ASX and the MX
MX is a high performance summer tire. Sticks like glue in warm weather and is fine as long as you don't have to drive in the snow or extremely cold weather
The ASX is an all-season tire - it's okay in the summer, okay in the winter and should be able to handle light now, but not really great at anything. Jack of all trades, master of none.
honestly I didn't care for the ASXs. I was very disapointed with their wet weather performance. Compaired to the MXs they hydroplaned a lot easier which was no fun.
I'm on my second set of MXs and drove the last set down to the cords. When it's time for new tires, I'll by them again (I've hear rumors of a 315/30-18 which would be very nice for my Z06 motorsports). I wouldn't buy the ASXs again.
I'm due to replace my OEM rumblers and have only read good things here about the Kumho's
I put the MXs on mine. They are quieter than the runflats that were on there and they are a lot smoother. I put Z06 swaybars on it a couple of months ago and wasn't real happy about how much it affected the ride quality, even with the F-45 on touring mode. Putting the non run flats on there just about brought the ride quality back to what it was before the swaybar change.
I put the ASXs on mine and have been happy with the road noise compared to the Goodyear Runflats that were on there before. The handling is sufficient for everyday driving and some spirited driving. I have not pushed the car to the limits in wet weather, but have not had a problem with normal driving in wet weather.
Report for: Kumho ASX
Long story short, I have gotten many miles from these tires (+30k miles, including 25-30ish drag strip prep burnouts and 1 or 2 showing out on the street super duper burnouts) and was blessed with an amazing 1.94 60ft last weekend with only a mild 'prep' burnout. For a M6 w/a stage 4 clutch, I dont think that is too bad. I think they hook up pretty good considering the treadwear rating. I have never had a hydroplaning problem, but then again, I am very careful and generally drive slow in the rain.
I am looking for more performance and grip, so I am thinking of going to the MXs on the rear, but I have heard that they are not expected to last even half as long as the ASXs.
Noise is not an issue to me, but my friend commented that he thought his were loud compared to the Supercars that came on his Zoh.
Eric
Eric
I had ASXs for a few months, I was not satisfied with it. I should had gone with the MX's since the C5 does not see wet weather.
I have Avon Tyres now from Tirerack. They grip hard, esp when warmed up. It's new so I have no long term reviews for it yet.
I just purchased the SPT's for the rear set. They are much quieter than the michelins due to the circumferential tread pattern. I went with 275's but should have gotten 295's.They don't grip well in cool weather, but they are quiet.
let me explain my hydroplane comment a little further.
I was in Germany when I had the ASXs Typically on a fresh set of MX tires (275/35-18/295/35-18) I would start to have problems on at wet autobahn at ~130mph. When I put the ASXs (245/45-17/275/40-18) on I couldn't break 90mph in similar conditions. No one in there right mind would be going that fast in the rain (I've never been accused of being normal) but there was a significant difference that i thought it was worth mentioning, even though the MXs were wider and in theory should be worse on wet roads.
How this would apply to normal people: the MXs can move more water out of the way so on wet roads you have a greater margin of safety at normal speeds and if you hit a large patch of standing water on a poorly maintained road, you're less likely to hydroplane.
Also, All the pictures from my old sig MXs on the Nurburgring
After reading the above comments it seems the MX is the most popular choice for overall performance but with poor tread wear compared to other Kumho's. Not to much comparison with the others for tire noise except lots of mention about the improvement ovey GY runflats (no surprise there). Hydroplanning information is there (above), thanks. Noise between Kumho Runflats and MX's hasn't been expressed; I assume other vette owners haven't had the experience with these two tire models to offer an opinion. Its a shame the ASX's don't perform better because it appears to be a quiet tire. Thanks for all the information offered, I appreciate it.
