Is WD 40 Ok?
Tastes like "chicken!" Just Kiddin' I've been doing this for a long time with no problems.
I just pour gasoline and rock salt onto my car. Then I let it sit for about 4 minutes. Just as the gas starts to evaporate, us a real "mild" steel wool and scrub the paint in a circular motion. Be sure to wash the car with soap and water afterwards to remove any steel fibers that were left behind.
a little gas on a rag breaks it up in seconds. just wash that area after it's done. ( we've all spilled gas on our cars and the gas station and forgot to clean off the drops)
CI 7-8 Veteran
WD 40 is fine to use on paint. It will remove any wax/sealer on in that area though. This includes Pinacle, Wolfgang, Zaino and any other type of protectant you may have put on the car. Re-wax the area you used the WD 40 on and you're good to go. I've done this before without any issues.
Man you guys crack me up....
Im now gonna leave all the bugs on the front of my car just to see how bad it can actually look after a couple months and easily wash them off with warm water and soap.
Cruise-In I Veteran
Yeah buddy!!!!
Lacquer thinner and sand works good too.
Guaranteed to remove those pesky bwugs and anything else on the fiberglass. The 'circular motion' is the best too.
Makes a good window cleaner too.
#33
#35
my problem was pine cone sap, it was like glue. when it turned hard it was like cement, just looking at it i knew clay barring would damage the paint. first i tryed a very hot rag and let it sit, that didn't work. i looked at a can of brake cleaner than came to my sinces.
#37
#38
Wd 40
Invisible Glass made by Stoner is for love bugs and any type of grease or oil on your car finish. After I wash the car I wipe the car down with a cloth with the IG and it comes out GREAT try it. Good Luck
#40
Here are some of the uses: WD-40
When you read the "shower door" part, try it. It's the first thing that has ever cleaned that spotty shower door. If yours is plastic, it works just as well as glass. It's a miracle!
Then try it on your stovetop...Viola! It's now shinier than it's ever been. You'll be amazed.
Protects silver from tarnishing.
Cleans and lubricates guitar strings.
Gives floors that 'just-waxed' sheen without making it slippery.
Keeps flies off cows. (Good to know)
Restores and cleans chalkboards.
Removes lipstick stains.
Loosens stubborn zippers.
Untangles jewelry chains.
Removes stains from stainless steel sinks.
Removes dirt and grime from the barbecue grill.
Keeps ceramic/terra cotta garden pots from oxidizing.
Removes tomato stains from clothing.
Keeps glass shower doors free of water spots.
Cam ouflages scratches in ceramic and marble floors.
Keeps scissors working smoothly.
Lubricates noisy door hinges on vehicles and doors in homes.
Gives a children's play gym slide a shine for a super fast slide.
Lubricates gear shift and mower deck lever for ease of handling on riding mowers.
Rids kids rocking chairs and swings of squeaky noises.
Lubricates tracks in sticking home windows and makes them easier to open.
Spraying an umbrella stem makes it easier to open and close.
Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
Restores and cleans roof racks on vehicles.
Lubricates and stops squeaks in electric fans.
Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
Lubricates fan belts on washers and dryers and keeps them running smoothly.
Keeps rust from forming on saws and saw blades, and other tools.
Removes splattered grease on stove.
Keeps bathroom mirror from fogging.
Lubricates prosthetic limbs.
Keeps pigeons off the balcony (they hate the smell).
Removes all traces of duct tape.
Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
Florida 's favorite use is: "cleans and removes love bugs from grills and bumpers."
The favorite use in the state of New York --WD-40 protects the Statue of Liberty from the elements.
WD-40 attracts fish. Spray a LITTLE on live bait or lures and you will be catching the big one in no time.
Also, it's a lot cheaper than the chemical attractants that are made for just that purpose. Keep in mind though, using some chemical laced baits or lures for fishing are not allowed in some states.
Use it for fire ant bites. It takes the sting away immediately, and stops the itch.
WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
Also, if you've discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and re-wash. Presto! Lipstick is gone!
If you sprayed WD-40 on the distributor cap, it would displace the moisture and allow the car to start.
WD-40, long known for its ability to remove left-over tape mung (sticky label tape), is also a lovely perfume and air freshener!
Sprayed liberally on every hinge in the house, it leaves that distinctive clean fresh scent for up to two days!
It removes black scuff marks from the kitchen floor!
Use WD-40 for those nasty tar and scuff marks on flooring. It doesn't seem to harm the finish and you won't have to scrub nearly as hard to get them off. Just remember to open some windows if you have a lot of marks.
Bug guts will eat away the finish on your car if not removed quickly!
Use WD-40!
Use WD-40!
