TB Bypass
Old 11-08-2006, 12:46 AM
SunDevil C5
SunDevil C5's Avatar
Default TB Bypass
I have the necessary parts just wondering which tubes to connect. I did this mod to my Camaro SS and I'm assuming its the same. Having a hard time locating the tubes. Does anyone have pictures of an install?
Old 11-08-2006, 12:48 AM
Blue02ws6
Blue02ws6's Avatar
It's the hoses that connect to the TB.
Old 11-08-2006, 12:57 AM
SunDevil C5
when i disconnected the tube from the lower left, coolant POURED OUT when i started it and didn't stop.
Old 11-08-2006, 01:02 AM
Blue02ws6
Blue02ws6's Avatar
Just put in the bypass as fast as you can, clean up the mess and check the coolant level.
Old 11-08-2006, 01:15 AM
SunDevil C5
The coolant wasn't coming from the hose. It was coming from somewhere else below the TB.
Old 11-08-2006, 01:19 AM
Blue02ws6
Blue02ws6's Avatar
It would have to be where you pulled the hose off of. Have you found both hoses that go into the TB? I would find both of them first and then oull them off and connect them with the bypass coupler.
Old 11-08-2006, 05:44 AM
vettenuts
vettenuts's Avatar
Trick is to pull the one coming from the radiator first, then hold it up in the air so it won't leak (tie with string or something. Then get the bottom one off and start your connections. Put in some rags or something to keep coolant off the belt.
Old 11-08-2006, 10:25 AM
Neil Baker
Neil Baker's Avatar
What does this TB by pass do???How is it Better??
Old 11-08-2006, 10:48 AM
SunDevil C5
Keeps the intake air cooler by not being heated up by the hot coolant being pumped through the TB.
To TB Bypass
Quick Reply: TB Bypass
