Oil Viscosity Question
Sorry if this has been asked before, and I suppose it has.
I've come to accept via Evil-Twin and others that GM 4718M has to be met for an oil in these cars. Fine with me, will do. Now, on to viscosity grade. My understanding is that the auto makers have pressure put on them to recommned the lowest viscosity that will do the job.
Question:
Is there a contraindication to using a 20W-50 that meets the GM 4718 spec in a C5? Is that a better idea than 10W-30 that meets the spec? This is a daily driver but I do step on it a few times each day. My air temps range from 25F (rarely) to 110F+ (often.) Thanks.
Question:
20w-50 is mostly used by road racing vettes because of consistent high rpms and the its long duration in a track session.
if your just a DD, 10w-30 is fine
Question:
Question:
Thanks,
I guess you're saying that the increased oil flow at startup from the 10W-30 is better for the motor in my situation than the increased high temp protection I'd get from the 20W-50? All thoughts are welcome, thanks again.
Originally Posted by nmbis2k
BTW - I have always used Mobil 1 10W-30. Just did my 24k oil change, and switched to the recommended 5W-30...and the highway MPG increased.
I use 0W-30 German Castrol in all my cars. You need to check the actual viscosity number on the oil you are using, the "30" specifies a range in Cst that the oil can fall in and still be called a "30". Mobil is at the bottom of the range whereas the German Castrol is near the top. Both are 30 weight oils though.
I would stick with 0W-30 (German Castrol), 5W-30 (Mobil 1 and others), or 0W-40 (Mobile 1).
The last one covers quite a range of temperatures and is used by Porche in the Boxster. (at least it was in the last generation of Boxster).
10W-30 is essntially, obsolete, as it offers no benefit to an engine that is not overly worn-out.
I use 5W-30 Mobil 1 in the winter, 10W-30 in the summer.
Burn about 1 quart every 3k with the 10W, a litle more than that with the 5W.
I don't know why 10W would be considered obsolete.
http://www.idavette.net/hib/C5diy/c5diy1.htm
_________________
"Since 1992, the factory-fill oil in Corvette engines, except '92 LT5s, has been a synthetic, 5W-30. Prior to that, as far back as the late-1970s, GM used a petroleum-based 5W-30 in Corvettes, except '90-'91 ZR-1s.
The reason GM recommends 5W-30 is it's the politically correct choice when fuel mileage is a prime consideration. The U.S. Environmental Protection Agency, which oversees fuel economy standards for cars sold in this country and believes 5W-30 oil is a significant energy conservation measure, pressures car companies into 1) using 5W-30s in new vehicles and 2) marketing them to service customers. In response to this pressure, many years ago a policy was made by GM at the corporate level that, with few exceptions, the recommended oil for all passenger vehicles be 5W-30.
When you read the "Maintenance and Lubrication" section of the 1997 Corvette Service Manual carefully, you soon find there are alternatives. The book states on page 0-47, "The recommended SAE engine oil viscosity is 5W-30, however, if the temperature is above -18¡C (O¡F) 10W-30 may be used." Not only is this true for C5 but the same or similar language appears in owner's or service manuals going back a decade or more.
While we dispose of used oil and filters responsibly, recycle our cans and plastic and keep our room air conditioners set for 78¡, the Technical Staff of Vette Magazine cares little about the fraction of a percent better fuel mileage we supposedly gain with 5W30 oil in our Corvettes. It is our opinion that high-performance engines regularly operated in above 0¡F outside temperature and in their intended duty cycles will maintain performance longer if an oil of different viscosity range is used.
Any 5W-30 engine oil, including the synthetic in C5s, uses chemical additives, called "viscosity-index (VI) improvers", to widen its viscosity range enough to make it a 5W-30. VI improvers contribute little to lubrication and can make a "multi-vis" oil less effective at high temperatures than an oil without them. This can become a problem when the oil is under high shear loads at temperatures above 225¡F. It becomes a potentially damaging problem when oil temp. approaches 300¡F. If your oil temperature in the pan is 250¡F or above, bet that oil temp in bearings is approaching 300¡. Near the piston ring lands and the upper sections of the cylinder walls, it is that or above.
Another characteristic of a 5W-30 that can be a problem in severe service is a relatively high evaporation rate at high temperatures compared to lubricants of more narrow viscosity range. A higher evaporation rate contributes to increased oil consumption and substandard lubrication in areas of high temperature.
There are no VI improvers in quality, 10W-30, synthetic engine oils and their high-temperature evaporation rate is less. Thus, 10W-30 synthetics are better lubricants in severe duty applications. For that reason, we recommend that any C5 owner, and, for that matter, the owner of any Corvette built since GM began telling us to use 5W-30Ñput a synthetic, 10W-30 oil in their engine.
A good choice is Mobil 1, 10W-30 synthetic. An even better choice is Red Line Oil's 10W-30. While it is a good product, to keep its cost reasonable, Mobil 1 is made with a synthesized-hydrocarbon, base-stock. Red Line uses a more costly, but higher-performing polyol-ester base stock as used in jet engine lubricants. Because of this, Red Line 10W-30 due has slightly better anti-friction characteristics and is capable of lower oil temperatures at a given ambient temperature and engine load. Additionally, at oil high temperatures during severe duty operation, Red Line offers more scuff protection when lubricating main, rod and cam bearings.
The second oil selection issue to address is the Service Manual statement that LS1s operated in North America use only an oil meeting GM Standard 4718M. The Manual also states that oils meeting 4718M might be hard to find outside North America and that LS1s operated in such places can use any 5W-30, 10W-30 or 10W-40 petroleum or synthetic oil meeting APIÊSJ and Association des Constructuers Europeens de l'Automobile (AECA) Standard 3-96.
In a survey of some mass-marketers selling major brand synthetic oils to the DIY, we found synthetics may or may not be labeled as meeting GM 4718M but all meet the American Petroleum Institute's (API) Service SJ and International Lubricant Standardization and Approval Committee (ILSAC) GF-2.
Using information provided by the the GM Powertrain Division and the Lubrizol Corporation, a chemical manufacturer that sells raw materials to the world-wide oil refining industry, we researched these different oil specs.. GMPT supplied the particulars of 4718M and Lubrizol's web site (www.lubrizol.com) had the test sequence requirements for API SJ, ILSAC GF-2 and AECA 3-96.
SJ and GF-2 have only minor differences, none of which affect the ability of oils meeting those specifications to lubricate. 4718M and 3-96 are similar, however, both differ from API SJ and ILSAC GF-2 in two critical measures: 1) the GM and the AECA standards require better performance in high temperature/high shear environments, two conditions present in any engine generating very high oil temperatures and 2) both 4718M and 3-96 require a lower oxidation rate, also a necessity in an engine generating high oil temperatures. Those differences mandate synthetic oil because petroleum-based oils cannot meet the higher requirements. Better high temperature/high shear numbers and lower oxidation rates are characteristic of all quality synthetic oils.
The Vette Technical Staff suggests C5ers looking to buy oil for their LS1s not worry so much about 4718M and look for a major brand of 10W-30 synthetic oil meeting API SJ or ILSAC GF-2. Examples are Red Line, Mobil 1, Castrol Syntec and Havoline Formula3 Synthetic. Those operating their Corvettes outside North America should use an oil that meets AECA 3-96. "
_________________
_________________
_________________
Originally Posted by Bob25thTA
Thanks so much! Fantastic!
p.s. I have to ask- are you "the Bob?"
EHS has some great info in post #12.
I use 15-W50 M1 in my track car.
Also talking with Penzoil / Quaker State aka Shell/Helix about a new 5-W50 co-developed by Hendrick Motorsports.
I've only glossed over that info and bookmarked it so far. What an absolute wealth of information! It will take me some time to digest. (But I will...)
No, just a messenger.
It's already been stated here, but I'll add my .02 to the list. 20w-50 is way too heavy for a DD car. Even in a race car, 20w-50 is used, amongst other reasons, because the engine is built "loose" and the heavier weight oil works well there.
OE engines are built to tight tolerances, hence the need to go to lower weight oils. I've been running M1 10w-30 and getting my oil analyzed by Blackstone labs. Based on the results of several analyses, I'm now running my LS-1 down to 0% on the oil life monitor, and my '94 Z-28's LT-1 10,000 miles between oil changes (about once every 7 months).
HTH, and have a good one,
Mike
Mike
