Transmission Fluid Manual 6speed Best
Old 10-25-2006, 09:29 AM
hhntr111
hhntr111's Avatar
Can you use Mobil 1 ATF in a MN6 tranny?
Old 10-25-2006, 12:40 PM
Hardtop01
Hardtop01's Avatar
Yes.
Old 10-25-2006, 02:05 PM
ericdwong
ericdwong's Avatar
Originally Posted by chiefDave
So how do you like fresh Mobil 1 compared to RP? My jump to RP gave me a huge increase in smoothness IMO. My old oil was Mobil1 but had some hard miles on it. I would like ot hear your experiances and opinions please
Thanks!!!
Dave
Well for me to buy the RP I have to drive to a store about 15 miles away, where the local Pep Boys has the Mobil 1. I think the Royal Purple is better it seems to shift smoother particularly since its getting colder out. Probably gonna go with Redline next.
Old 10-25-2006, 02:31 PM
dwjz06
Dogface
Support Corvetteforum!
dwjz06's Avatar
St. Jude Donor '15, '17
Amsoil here. No problems so far!
Old 10-25-2006, 02:49 PM
chiefDave
chiefDave's Avatar
St. Jude Donor '05-'06
Thanks for the response man! Funny there is a Pepe Boys 1/4 mile from my house too (thats one reason I moved in there) and they have RP but no syncro mesh I'm with yuo and are going to try redline soon. I do the clutch fluid before each trip to the track, and like to do the oil every other month, and I have not done the trany since Aug??? Thanks!!!
Dave
dleonidas (04-12-2021)
Old 10-25-2006, 07:34 PM
ZeeOSix
ZeeOSix's Avatar
Originally Posted by Dan_the_C5_Man
I've completed a fair amount of research on this as well, and my determination is "if you have paper blocking rings and you are running Redline D4 ATF (or ANY synthetic ATF for that matter), the "damage" is done, might as well go for the MTL with superior gear protection (especially for the track).
So what year Vettes have trannys with paper blocking rings? I keep hearing this stuff, but nobody has a definite answer on which cars have them.
I found this on the web, so at least it looks like all Z06s have carbon blocker rings.
M12 6-Speed Manual
"Synchronizers -- Carbon blocker rings have been installed on all manual transmission forward gears to provide for smoother shifts and additional robustness."
Hummm ... what about reverse, it's not a "forward gear".
Old 10-30-2006, 01:56 PM
N0TDADYS_98
N0TDADYS_98's Avatar
http://forums.corvetteforum.com/show....php?t=1536152
this helps answer some of the questions about what oil can be used in the early c5's (97-99) that may potentially have paper blocking rings.
i've not confirmed if they are paper or graphite.. I assume they are paper (worst case senerio)
Old 10-30-2006, 03:18 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
I've run M1 in my '94 Z-28 (similar T56 internals) and my '00 FRC. 188K miles on the Z28, 146K miles on the FRC.
Best thing about the M1 is it's easy to get.
Have a good one,
Mike
Old 01-03-2007, 11:00 AM
N0TDADYS_98
Bump just so those who haven't seen this yet.
Old 01-03-2007, 11:50 AM
Bob25thTA
Bob25thTA's Avatar
Changed from Mobil 1 ATF to Royal Purple Synchromesh. Shifts smoother so far.
Old 01-04-2007, 10:21 AM
Corvette Don
Corvette Don's Avatar
BTW guys its royal purple synchromax, lol, but you can run this stuff in the mn6 even though its not ATF fluid??
Old 01-04-2007, 10:31 AM
N0TDADYS_98
Yes, you can run syncromax in an MN6 (which it was designed for) and it's ok in all years including those that "might" have paperblockers.
Old 01-04-2007, 10:38 AM
  #33
Corvette Don
Good deal, im getting rid of the royal purple MAX AFX today (its syn.), I have hard shifts in the morning with it but they go away after 30 mins of driving so ill see if that stuff does any better
Old 01-04-2007, 11:06 AM
  #34
chuckster
chuckster's Avatar
GM Synchromesh here..
Old 01-06-2007, 03:27 AM
  #35
striper
striper's Avatar
I have tried Mobil 1 and Dexron VI in mine. I am now using Royal Purple Synchromax and I like it the best of all I've tried. Shifting is real smooth, especially going into 6th and also when downshifting into any gear it just slides right into gear.
Old 01-06-2007, 03:46 AM
  #36
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Redline MTL working fantastic so far, slightly notchy during the first 3 or 4 miles (I don't think any formulation would completely cure this), much smother than with the D4 ATF after that.
Old 01-07-2007, 01:16 PM
  #37
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Originally Posted by 2KFRC5
Can Dexron VI be used in the manuals, or is it only for the autos?
The Dexron VI spec is currently only for the autos, but for those looking for an aftermarket alternative to the new GM fluid, the AMSOIL ATF was recently reformulated to meet the new Dexron VI specification, but is backwards compatible and still meets the Dexron III specification. Since the AMSOIL distribution centers still have some old formulations on the shelfs, be sure to order batch #10189 or higher to get the new version.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
To Transmission Fluid Manual 6speed Best
Old 01-07-2007, 05:18 PM
  #38
2KFRC5
2KFRC5's Avatar
This states that Dexron VI is also backward compatible for all earlier applications.
http://www.gm.com/automotive/gmpower...ll_Release.doc
Excerpt:
All DEXRON®-III licences[sic] expire at the end of 2006 and will not be renewed. Beyond that date GM will only support the use of DEXRON®-VI fluids for use in Hydra-Matic transmissions. Fluids sold in the market after that date bearing claims such as “suitable for use in DEXRON®-III applications” or similar wording should be avoided. DEXRON-VI licenced[sic] fluids are fully backward compatible and can be used in all applications covered by earlier GM ATF specifications.
Old 01-07-2007, 09:15 PM
  #39
Z06Plasticfantastic
Z06Plasticfantastic's Avatar
Redline D4. Will feel like a different trans.
Old 01-08-2007, 02:15 AM
  #40
John Galt
John Galt's Avatar
Originally Posted by vettenuts
I voted for Amsoil because that is what I am now using, not because I have any information to indicate it is the best. I am intrigued by the Redline MTL, but haven't got the nerve to try it.
How do you like it vs. stock?
Quick Reply: Transmission Fluid Manual 6speed Best
