Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-21-2006, 12:08 AM   #1
Dr. Pham
CF Senior Member
Dr. Pham's Avatar
Default Transmission cooler lines which is which?
Hello,
So from what i could search it seems that the top tranny line going into the radiator is the return line back to the transmission and so the bottom line is the flow from the trans to the cooler.
But what if those two lines were disconnected and "mixed-up"? Is there an easy way to tell which line is which just by looking at them?
thanks!
Dr. Pham is offline   Reply With Quote
Old 10-21-2006, 07:29 AM   #2
patton
CF Senior Member
St. Jude Donor '09
patton's Avatar
as they lie natraly ya can see where they go. if not i wont hurt to mix them up. the tough part is making sure they dont move ,hit or rub
patton is offline   Reply With Quote
Old 10-21-2006, 07:50 AM   #3
SteveDotenMotorsports
Former Vendor
Cruise-In VII Veteran
SteveDotenMotorsports's Avatar
they are preformed to fit both lower and upper
SteveDotenMotorsports is offline   Reply With Quote
Old 10-21-2006, 08:12 AM   #4
AU N EGL
CF Senior Member
AU N EGL's Avatar
Bottom is the drain line, or too the radiator. Top is fill, or from the radiator.
If you put them in the other way around, the top line most likely will not pull fluid out to the radiator.
Your trans is not 100% of trans fluid, it is close, but not 100% so no suction to pull out fluid from the top.
AU N EGL is offline   Reply With Quote
Old 10-21-2006, 02:55 PM   #5
Dr. Pham
CF Senior Member
Dr. Pham's Avatar
Thank you very much gentlemen! Your posts are most appreciated.
A little more detail. The tranny lines were disconnected to bypass the radiator and hook up to an external oil cooler. Earl's Temp-a-cure brand.
I bought a second bigger cooler (same brand) and noticed that it has a directional flow arrow between the two fittings. So I started wondering if the lines were hooked up in the right order. Since I was going in today to put in the bigger cooler I could easily fix it if I new which line was which.
Good thoughts on just seeing where they are preformed or naturally line up from the factory.
Golden Eagle- just to confirm are you saying that the line going into the top of the radiator is the flow FROM the trans to the radiator and the line at the bottom is from the radiator TO the trans?
thanks!
Old 10-21-2006, 03:55 PM   #6
AU N EGL
CF Senior Member
AU N EGL's Avatar
Quote:
thanks!
Dah I though you were talking about the trans connections. Let me go look at mine.
Edit: NO. The way mine is set up from the MN6 trans; bottom out of the trans into the bottom connection on seconday trans radiator ( cooler). This way any air bubbles are pulled or suck out of the radiator to the trans pump in the right rear wheel well and back to the transmission or when filling the lines and trans radiator I have the return line drain into an empty bottle to make sure the lines and trans radiator are full.
Pump in right rear wheel well
Click the image to open in full size.
Radiators
( left) trans (back) AC condensor ( right) oil cooler [ old pick - no AC condensor now ]
I do not recoment a t-stat, but a manual switch to turn on the radiator pump. t-stats have been known to fail at high temps and you want those coolers running well before it is too late.
I do not use the trans cooler on the street, what little time the car spends on the street, but when I leave the pits I turn on the trans pump. Son of a gun is almost too loud, until I step on the thottle then I dont hear it.
Old 10-21-2006, 04:36 PM   #7
Dr. Pham
CF Senior Member
Dr. Pham's Avatar
Thanks Nice set-up!
Old 10-22-2006, 11:23 PM   #8
Dirty Howie
CF Senior Member
Support Corvetteforum!
Dirty Howie's Avatar
The line to the top of the radiator is the return line to the tranny....this is where you should be splicing in your cooler !!!!!!
And if you cooler has a directional flow ...... IN would be from the radiator and OUT would be towards the tranny.
Got it ??? ..... you know I know
DH
__________________
BOARD MEMBER OF THE 2014 CORVETTE CHALLENGE
ORGANIZATION SPONSORS
Speed Ventures
GOLD SPONSORS
LG MOTORSPORTS
FINSPEED
SILVER SPONSORS
CUNNINGHAM MOTOR SPORTS
EXCELSIOR MOTORSPORTS
KNSBrakes
CALIFORNIA SERVICE CENTER
REVOLUTION MOTORSPORTS
CANYON RUN VIDEO
LSX ADVANCED AUTO
TWAY MOTORSPORTS
Dirty Howie is offline   Reply With Quote
Old 10-23-2006, 12:01 AM   #9
Phil97SVT
CF Senior Member
Phil97SVT's Avatar
Send a message via AIM to Phil97SVT
I thought the guy from Dewitts said that you should put the trans cooler on the feed line, his thought was to cool the trans fluid and than warm it back up to your 170 degree temps. He said that if you put the trans cooler on the return line it would probably cool the trans fluid too much.
Phil97SVT is offline   Reply With Quote
Old 10-26-2006, 03:38 AM   #10
Dr. Pham
CF Senior Member
Dr. Pham's Avatar
Howie! Oh I know you know! I am actually bypassing the radiator completely and just running it through a good size cooler. http://store.summitracing.com/partde...410ERL&FROM=MG
Once I crawled under the car figuring out which line went where was pretty obvious. Everyone was right the lines are preformed in a was so you know which is the top and which is the bottom. They were originally disconnected and run through a smaller tranny cooler so I was worried I'd have a hard time figuring them out since they weren't connected to the radiator...but no worries...thanks for the replies guys!
So now 've got a much bigger cooler in there with a 10 inch puller fan. The lines are running like you said Howie! The bottom trans line runs into my cooler and then back out to the tranny. I noticed a directional flow arrow on the cooler so just thought to play it safe, besides I was also trying to wire in a temp sender so teh fan only comes on at a certain temp.
Right now I need to find a 12v signal to trigger the relay to the fan that is only on when the engine is running.
As for cooling the trans fluid too much...I have a Yank 3200 SS converter and (without the fan hooked up yet) temps got up to 196 after about 45 mins of "spirited: driving and stayed there. Though to be fair I didn't end up in stop and go traffic which is where the fan would have really helped.
I'm going to add to another previous post about trying to find a 12v trigger. So if any one knows...please fill me in
thanks!
Old 10-26-2006, 09:14 AM   #11
94legaleagle
CF Senior Member
I'll need to find this information this winter for mods
94legaleagle is offline   Reply With Quote
Old 10-26-2006, 05:09 PM   #12
Dirty Howie
CF Senior Member
thanks!
Looks like a good sized cooler. As long as you keep the temps below 200 you are golden......
DH
Old 10-27-2006, 11:16 AM   #13
todd@rpmtransmissions
Premium Supporting Vendor
todd@rpmtransmissions's Avatar
This is a picture of a typical 4L60E, the Corvette lines are the same.
todd@rpmtransmissions is offline   Reply With Quote
Old 10-27-2006, 11:39 AM   #14
kromberg
CF Senior Member
kromberg's Avatar
Which line would be better to add a tranny temp gauge: return coming into the tranny or the send coing out of the tranny?
Keith
__________________
Y2K C5
Pewter Exterior / Black and Grey Interior
F1-R and 402 LQ4 Dragon Pro Street
10.46 @ 130 at 6800'
kromberg is offline   Reply With Quote
Reload this Page Transmission cooler lines which is which?
Tags
1984, 700r, c5, c6, cooler, coolers, cooling, corvette, directional, flow, line, lines, replace, routing, tranny, transmission
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is the Transmission toast? blktie8 C5 Tech 11 07-07-2004 12:27 PM
Transmission Line routing for 700R with external cooler? steve40th C4 Tech/Performance 10 07-04-2004 05:53 AM
Transmission cooler question, is mine working? cjones C5 Tech 23 06-26-2004 01:46 PM
Ron Davis Radiator w/ Oil Cooler Hammer C4 Tech/Performance 10 07-14-2003 08:28 AM
Transmission Coolers.......should I get one?? Mr. Magoo C4 Tech/Performance 19 12-13-2002 06:31 PM
Yet Another Transmission Cooler Question Mag Red Monster C5 Tech 17 05-28-2002 03:54 AM
Transmission and Differential Coolers for C5 alan33 Autocrossing & Roadracing 34 11-12-2001 12:06 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
