L92/L76 402 Project
Originally Posted by connecticut
nice setup, this is the first L92 build I've seen on the forum
what fuel rail do you use w/ the 76 intake?
We're not sure on the fuel rails yet but since I've got the return line system adding aftermarket rails will be a since if I have to go that way.
Originally Posted by 99blackFRC
Are they like the LS7 rails (5* angle)? If so we've got a couple sets that we fabbed up. Should be ready this week, if not already completed.
does anyone out there have the 76 intake in the states, other than this member?
UPDATE:
We finally got the Bret Bauer cam yesterday. It took Comp a while to find a blank that would work with Bret's cam and lobe design. This is definitely not an off the shelf grind.
The bottom end can go together now. The next step is to check the P/V clearance and flycut as necessary.
Maybe Phil97svt can get some pics up as we progress with this build.
Originally Posted by Gene@FredBeans
Hi All,
I have 3 sets of heads and intake combos. If anyone is interested please let me know.
Thanks,
Gene.
Thanks,
Gene.
#35
Originally Posted by phils C5 vette
What's the deal on your ride. Is it done yet?
#37
#39
Sure, im ready for another cam.
Have you learned to tune cars yet. Mr. HP Tuner Specialist ?
Ill "ask the expert" next time.
