Decarb: Sea Foam or GM Top Engine Cleaner?
I plan to do decarb my Vette this week. Should I use Sea Foam or GM Top Engine Cleaner? Which one is better?
Also, have anyone added Sea Foam to the oil crankcase per Sea Foam suggestion?
http://www.seafoamsales.com/motorTuneUpTechGas.htm
When Added to Crankcase (Oil)
1. Frees sticky lifters and rings
2. Increases R.P.M.'s vacuum and compression
3. Cleans dirty parts
4. Removes moisture
5. Cleans PCV valve systems
One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart).
Thanks.
4. Removes moisture
Thanks.
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
How many miles do you have on the car?
I like seafoam, myself.
Are you going to do the overnight cleaning?
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
I have seen many good experiences with the GM stuff, but not in all applications. It works better on high mileage or highly carboned up motors.
GM top engine cleaner and SeaFoam are very similar though not identical in composition. Both do the same job. I can't tell if one is better than the other. I have used them both.
Cruise-In IX Veteran
I have always used Seafoam. The stuff works great have been using it for years now. Never tried the GM stuff cause I can get Seafoam locally and it has always worked.
I have 25K miles on the clock and this will be my first time to do the decarb. Not sure I need it at 25K or not. Do I need one or two bottle to do the job?
So Has anybody added Sea Foam to the oil crankcase? Thanks.
Nope, the only way to use too much is to pour five cans in the crank case so that you over fill. I used two cans of sea foam last time (1.5 through the pcv system, the other .5 in the crank case).
One other thing. When you add to the crank, should you change the oil any time soon? Some have said within 500 miles, this true?
What the .... is Sea Foam
I have a '98 coupe with 83K on the clock (bought at 78K) and may be overdue for a number of maintenance items ignored by prior owners. Planned things include changing out coolant, M6 trans fluid, rear end lube, brake fluid and the dreaded clutch master and slave cylinders. More years ago than I will EVER admit to, adding a cleaning compound with aggressive cleaning qualities to the crank case, running it for 30 minutes or so at idle, and then changing the oil was relatively common and cleaned an engine so that oil even after a few hundred miles the new oil wouldn't be black.
Is Sea Foam a similar type of product? Are there products used for the fuel system as well as the crankcase? Any chance it might be available at O'Reilly's, Pep Boys, or similar?
Charlie
Charlie
Charlie
Charlie
I checked O'Reilly and...
Originally Posted by sugarwolf
They got it at shucks or autozone or napa
Charlie
A question for anyone that has disassemble an LS1 that was run 100% on Mobil 1. Did you find any varnishing or sludge that would have been cleaned by Seafoam or GM cleaner?
Charlie
St. Jude Donor '05, '14, '15
I did the GM decarb a few weeks ago, let it sit for about 2hrs, then cleared it out... wow! have around 90K on her... and there was some smoke and some interesting crap coming out , lol....
I changed my OIL and plugs/wires afterwards as well... the plugs had some sludge build up that I am pretty sure came from the decarb... but all in all, the car runs so much smoother and idles so nice!
throttle response is much better now too! (probably from the plugs/wires)
does the seafoam remove intake carbon deposits?? used through the gas tank? i recently removed intake to change oil gauge and noticed the intake port was caked over w/carbon? or is the carbon normal?
Intake deposits
In answer to your specific question, because it's a dry intake, the intake will never "see" the Sea Foam so it won't remove deposits. If the deposits are bothersome, pull the intake, clean, and replace it. I don't know if there is a completely safe way to remove these deposits with the intake on the engine.
Charlie
