Blower Motor not working
Old 08-08-2006, 10:57 PM
bubs99
bubs99's Avatar
Default Blower Motor not working
1999 6 spd with manual air - Had water back up in blower motor area. Motor stopped working, checked fuse ok replaced BM resistor still no blower motor. Hooked motor up directly to battery no spin. Took motor apart and cleaned brushes then tested directly to battery with jumpers motors spins. Connected to resistor lead still no blower. Is there a relay I am failing to find or control module ????Not sure what to do next.
Have power going into resistor but nothing coming out.
also cleaned out ac drain and all kinds of debris came out. sucked it out with a shop vac.
Please help....
bub
Old 08-08-2006, 11:27 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,919 Likes on 5,328 Posts
What year car do you have and do you have manual or automatic air? There are some differences.
Bill
Old 08-09-2006, 07:29 AM
bubs99
bubs99's Avatar
1999 6 spd hardtop - manual air.
Old 08-09-2006, 06:26 PM
bubs99
bubs99's Avatar
Anyone?????
Old 08-09-2006, 06:55 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
7/32" socket; pull the motor 3 screws, work it free by hand, spray wd-40; or new one for $80; i spent $2 on wd-40
Old 08-09-2006, 07:02 PM
bubs99
bubs99's Avatar
Motor spins I can't get it to come on. Tested it directly to battery. Replace resistor and checked fuses. Is there a relay I need to check or ???
Old 08-09-2006, 10:39 PM
Bill Dearborn
Blower Motor Relay
Mounted on the multi use relay and fuse bracket, above the Body Control Module (BCM).
Here is a diagnostic from the Service Manual.
Document ID# 376581
1999 Chevrolet/Geo Corvette
Blower Motor Inoperative at Any Speed
Blower Motor Inoperative at Any Speed <<C60>> Step
Action
Value(s)
Yes
No
DEFINITION: Blower motor is inoperative at any selected speed.
1
Were you sent here from the HVAC System Check (C60)?
Go to Step 2
Go to HVAC System Check
2
Disconnect the blower motor connector.
Turn the ignition switch to the ON position.
Place the HVAC mode switch in the UPPER position.
Turn the blower switch to the LO position.
Connect a DMM between terminal A of the blower motor connector and a known good ground.
Measure the available voltage at terminal A of the blower motor connector.
Is the voltage within the specified values?
10.0 -14.0V
Go to Step 3
Go to Step 10
3
Connect a DMM between a good ground and terminal B of the blower motor connector.
Measure CKT 150 for continuity to ground.
Is the resistance to ground less than the specified value?
0.5ohms
Go to Step 4
Go to Step 5
4
Replace the blower motor. Refer to Blower Motor and Fan Replacement .
Is the repair complete?
5
Disconnect the blower motor control module connector C2.
Connect a DMM between the blower motor control module connector C2 terminal 2 and a good ground.
0.5ohms
Go to Step 6
Go to Step 7
6
Locate and repair an open or a high resistance in CKT 150 (blk wire) between the blower motor connector and the blower motor control module connector C2.
7
Disconnect the blower motor control module connector C1.
Connect a DMM between the blower motor control module connector C1 terminal E and a good ground.
0.5ohms
Go to Step 8
Go to Step 9
8
Replace the blower motor control module. Refer to Blower Motor Resistor Replacement .
Is the replacement complete?
9
Locate and repair an open or a high resistance in CKT 150 between the blower motor control module connector C1 and G202.
10
Disconnect the blower motor relay.
Connect a DMM between the blower motor relay connector terminal A1 and a good ground.
0.5ohms
Go to Step 12
Go to Step 11
11
Locate and repair an open or a high resistance in CKT 150 between the blower motor relay connector and G202.
12
Connect a DMM between the blower motor relay connector terminal C2 and a good ground.
Measure the available voltage at the blower motor relay connector terminal C2.
10.0 -14.0V
Go to Step 16
Go to Step 13
13
Check the HVAC MiniFuse® #18 for an open circuit.
Is the fuse open?
Go to Step 15
Go to Step 14
14
Locate and repair an open or a high resistance in CKT 41 between the blower motor relay connector and the instrument panel electrical center.
15
Locate and repair a short to ground in CKT 41 between the blower motor relay connector and the instrument panel electrical center.
16
Connect a DMM between the blower motor relay connector terminal C1 and a good ground.
Measure the available voltage at the blower motor relay connector terminal C1.
10.0 -14.0V
Go to Step 20
Go to Step 17
17
Check the BLO MOT MaxiFuse® #49 for an open circuit.
Is the fuse open?
Go to Step 19
Go to Step 18
18
Locate and repair an open or a high resistance in CKT 1342.
19
Locate and repair a short to ground in CKT 1342.
20
Reconnect the blower motor control module connectors.
Reconnect the blower motor connector.
Connect a fused jumper wire between the blower motor relay connector terminal C1 and terminal A2.
Turn the blower motor fan switch to the low position.
Does the blower motor operate?
Go to Step 21
Go to Step 22
21
Replace the blower motor relay.
22
Fused jumper wire is still connected between the blower motor relay connector terminal C1 and terminal A2.
Disconnect the HVAC Control Assembly connector C2.
Connect a DMM between the HVAC Control Assembly connector C2 terminal B and a good ground.
Measure the available voltage at the HVAC Control Assembly connector C2 terminal B.
10.0 -14.0V
Go to Step 24
Go to Step 23
23
Locate and repair an open or a high resistance in CKT 42.
24
Connect the blower motor connector.
Connect the blower motor control module connectors C1 and C2.
Connect a fused jumper wire between terminal B and terminal H of the HVAC Control Assembly connector C2.
Go to Step 25
Go to Step 26
25
Replace the HVAC Control Assembly. Refer to Control Assembly Replacement .
26
Replace the blower motor control module. Refer to Blower Motor and Fan Replacement .
Document ID# 376581
Bill
Old 08-12-2006, 04:23 PM
bubs99
bubs99's Avatar
Default Blower motor working again
Thanks to Bill and the schematic he sent me I was able to trace my fan motor not working. Turned out to be the relay. But without the schematic I wouldn't have found which one it was. So thanks to you Bill for your responses.
Bub
Old 04-02-2018, 10:31 AM
Butz
1st Gear
Butz's Avatar
Default Replaced resister
98 C5 replaced resister .....blower working correctly now
1.tested motor once out worked with power
2.tester showed power coming out of the old resister but would not operate motor correctly
3.pulled resister out looked fine but decided to replace it anyways
4. 50$ at Napa had it on the shelf "updated replacement" put it in everything working like brand new again
Old 04-02-2018, 12:41 PM
Carl Timonen
Carl Timonen's Avatar
To Blower Motor not working
Quick Reply: Blower Motor not working
