Throttle Body Bypass ??
Re: Throttle Body Bypass ?? (Buckmaster)
I wouldn't do it where you live! If you lived in the south or some place it doesn't get cold then it will give you a little extra 1/2hp max
Best of luck!
T
Best of luck!
T
It's a smal gain but only tacks 10min to do it. I ran my car all last winter and dident have a problem. 10min to go back to stock in winter if you want to. You can find the right size "barb" in the hardware store for 1-2 bucks. Ric
Is this simple mod worth it? Will it have any negative affect by the coolant NOT running through the TB? It does for a reason I would guess. Thanks
GM makes it generic to work everywhere, so that's why it's like that on all C5s (and other makes). Down in the South, we don't need it, so that's why I'm bypassing the coolant later this week. The principal behind it is that the hot coolant warming the throttle body actually heats the air to an extent as it passes through the throttle body. Cooler air equates to increased horsepower, so bypassing the coolant (if appropriate for your location) should give you a little bit cooler air. The Forum Mall has it for $10 on sale. I paid $20 for mine. It's a cheap and easy mod. Might get 1 or 2 hp increase from it depending on circumstances.
Re: Throttle Body Bypass ?? (TargaC5)
if you decide to install this mod,purchase a set of rubber vaccum caps.install them over the inlet and outlet of the t.b. to keep dust ,dirt etc... out. :yesnod:
This mod is probably a waste of time, especially where you live. Use your time to detail it instead! :yesnod:
[Modified by carpe dm, 11:56 AM 9/6/2001]
