Doors don't unlock!
Doors don't unlock!
I own a 2001 with only 10K on it. The passenger door was failing to open by FOB or by both interior open buttons in 2004. This year the drivers door fails to open by either method. Every thing else on the doors work by button or FOB. No codes are present and you can hear the clicking in the doors (DCM?) but will not open. This is embrassing to always use a key for entry. Help!
I have a 2003 vert, left window would not go up and then noticed left door would not lock or unlock. Just got word from the dealer that a circuit board has a fault and needs to be replaced. Car has 14K and went out of warranty, fortunatly I purchased extended warranty plan.
Goood Luck
Goood Luck
My driver door would not lock with the fob or lock button. The control board was fried, and was replaced under extended warranty.
