Gotta question for all you physics majors
#41
Originally Posted by cenzo
Obviously you guys were asleep during physics class!
The pass from East to West will be quicker since you have to consider the speed and distance of the earth's rotation under the car. In effect, the finish line will have moved closer during the East/West run and farther away during the West/East run. Basic Physics 101, no? Relativity is irrelevant here.
The whole dragstrip/car/everything on the earth is rotating together.
Relativity is irrelevant? Frictionless bearings? The car is floating? Keep going, you're cracking me up!
Ryan
#42
Man, you all have completely missed this one. You just think your drag racing when in fact, you are simply plugged into a program generated by the matrix . Think about it, why else would the ricers 'think' they can take a Vette!! Rotation of the Earth is irrelevant when you're simply part of a field of batteries!
Jeez, I think I've really lost it now. I gotta lay down!
#43
But if you're aiming east and spinning your wheels, wouldn't you be slowing down the Earth's rotation by a small amount? Why would you want to do that? It's bad enough that the government wants to get rid of leap seconds - and now you're adding a whole new problem to that issue!
- Wisdom
- Wisdom
#44
Originally Posted by 96-speed
The finish line isn't moving closer to the car. That is completely wrong. Ask yourself: How could the finishline move closer to the car, assuming the car is at a stand still?
Ryan
Ryan
#45
- Wisdom
- Wisdom
#47
Now it's obvious that some folks here are just having fun with this topic, but it's hard to tell with others......
PLEASE, PLEASE, restore my faith in you guys. Tell me you are kidding. There's no one here that REALLY BELIEVES there will be a difference...... Is there?????
#49
I think everyone is not taking into acount that though the earth spins on it's axis it also rotates around the sun. the sun is in a system that rotates around a galaxy and so on and so on. My point is that at these rotational forces act equally on all bodies at a fixed point in space (x Y axis). The force that causes acceleration is the friction of the tires on the surface of the earth. Cars don't have enough mass to cause the eath to change direction that's wy the car moves and the earth does not. So, on the surface of the earth no matter what direction you travel the direction of the rotation of the earth does not effect E.T.
#50
- Wisdom
- Wisdom
It depends, if someone is breaking wind in the other direction it will cancel out any effect.
#51
Originally Posted by Boeingman
If your time keeper was standing on the planet earth, no, time would not be efected as observed on the ground. However, if your time keeper was standing, or say floating, motionless in outer space somewhere then yes, your quarter mile times will be efected as observed by him out there in space.
I think Einstien's relativity theory explains this in better detail.
For a better example. Say your in an airplane playing catch while the aircraft is in flight and traveling at a great velocity. As you throw the ball say 50 ft inside the tube you can note the time that passes for the ball to travel this 50ft as you observed from inside the aircraft.
However, if you had a guy standing on the ground measuring the time and distance and he somehow had xray vision and really good distant vision he could see when you released the ball and when the ball made it to the 50ft mark (50ft mark over the ground). Now since the speed of the aircraft assited the trajectory of the ball by the speed of the aircraft itself, the 50 ft distance the ball travels is so much more quicker than when mesured from inside the aircraft.
It all depends on where you mesure from , be it time or distance...Relativety thank you Einstien
Hope I didn't confuse
Matt
Matt
#52
Originally Posted by nwdanner
Well said! It's all about "frame of reference".
can someone explain to me why the time it takes for the ball to travel from POINT A to POINT B would be different whether your measuring from in the plane, on the moon or floating in space??
While you're at it, tell me if the the ball's ET will be the same if thrown from front to back as if thrown back to front.
Thanks in Advance,
Vince
#53
In the above scenario,
Thanks in Advance,
Vince
Thanks in Advance,
Vince
http://en.wikipedia.org/wiki/Inertia...e_of_reference
http://en.wikipedia.org/wiki/Frame_of_reference
#54
Hi nwdanner.
I've read the links provided. Could you point out which part relates to Elapsed Time vs observation point? I'm really not as smart as I think I am.
Thanks again,
Vince
Thanks again,
Vince
#55
Hi nwdanner.
Thanks again,
Vince
Thanks again,
Vince
It's nice to see interest in this stuff. This very topic, along with Quantum/String theory, facinate me more than anything else (Corvettes included, but don't tell other forum members ). In fact, my "library room" at home has more science mags in it than car mags. I'm definitely no expert, just an "enthusiast" of the topic.
I tried to write up a nice analogy to explain it, but there are MANY other papers/sites out there which do a better job of it. Just go to Google/Yahoo and do some searches. For example, HowStuffWorks.com has a nice overview of this topic, which is available here: http://science.howstuffworks.com/relativity.htm
In short, the observation of time T between points A and B *appears* constant as long as the reference frames are traveling relative to each other at very small fractions of the speed of light. As noone can throw a ball, drive a car, or otherwise travel between points A and B anywhere near the speed of light, T will *appear* to be constant.
Again, there are TONS of books/websites out there which attempt to explain it. If you have time, dig into it. It's quite facinating and enlightening.
