Ls7 clutch
Old 06-27-2006, 02:07 PM
jbusmc1986
jbusmc1986's Avatar
St. Jude Donor '06
Default Ls7 clutch
What is the max hp/tq for an ls7 clutch and what parts are needed for the swap... I will be making about 440/460 na with a 150 shot...Wil the ls7 clutch hold up?
Old 06-27-2006, 02:15 PM
SnowyATX
SnowyATX's Avatar
You probably ought to do a search as there are a bazillion recent posts on this subject.
Old 06-27-2006, 02:16 PM
Z06ufgrad2002
Z06ufgrad2002's Avatar
150 shot on top of 460? No way it will hold that for very long.
I'd say a safe bet would be ~550 fwhp. Beyond that and you'll need something stronger.
Old 06-27-2006, 02:43 PM
jbusmc1986
jbusmc1986's Avatar
St. Jude Donor '06
Default yikes
That was what I had figured but I hoped that I would be ok... any one know of any alternatives that arent sooo expensive that will hold about 600 rwhp?
Old 06-27-2006, 05:54 PM
M_T_0
M_T_0's Avatar
are you running DR's?
if not the 06 Zo6 clutch should be fine.
I'm not running DR's but I have found the clutch to be great and hard to tell from a stock part when driving. BTW TQ is what kills clutches not HP (well that and how you use it)
More Than Zero
Old 06-27-2006, 11:06 PM
Ranger
Support Corvetteforum!
Ranger's Avatar
I have 33 passes on an LS7 clutch and the news is not favorable.
Of the dozen or so C6Z owners that I been to the track with, not one has good things to say about the LS7 clutch.
It should be fine for guys who like to drive on the street. But it hates launches and will glaze at a launch rpm over 3500 and it won't tolerate any slip even at 2500. The pedal gets hung on launch at least 25% of the time.
In contrast, I had 500 launches on C5Z with a stock LS6 clutch and it glazed twice and the pedal stuck once.
So, I don't recommend the LS7 clutch...to anyone that ever intends to launch the car.
Ranger
Old 06-28-2006, 10:52 AM
jbusmc1986
jbusmc1986's Avatar
St. Jude Donor '06
Default ooh
well that was kinda what I was expecting and with the hp and torque that I'll have that just wont hold up... I run bfg drags and love the track so I am going to be buying lots of expensive parts soon... to keep up with the go fast parts.
Old 07-18-2006, 11:05 AM
keliente
keliente's Avatar
Ranger
Bump, are there others with the LS7 clutch? I was thinking it would be a good choice until I read Ranger's critique.
I use my car for everything - daily driving, auto cross, and drag racing (in that order) so I need a clutch that can wear many hats as they say I don't plan on making but 400hp if that, and I want to stay away from SPEC because of the horror stories.
Old 07-22-2006, 04:19 PM
Gene@FredBeans
Gene@FredBeans's Avatar
Hi there,
Here is all the recent part number and pricing info!
||--Genuine GM C6 Z06 Clutch Components--||
24237690 – LS7 Clutch
12571611 – LS7 Flywheel
Both LS7 Clutch and LS7 flywheel are 533.30 shipped.
For both clutch and flywheel on our website, use part number ls7clutchkit under Chevrolet make.
89059282 - LS6 Slave Cylinder – 101.83
12564455 - LS6 Master Cylinder – 103.86
14061685 – Pilot Bearing – 9.53
*Clutch does work in any LS1/LS6 drivetrain but must also have ls7 flywheel. Also, can only use LS1/LS6 hydraulics.
Old 07-22-2006, 04:37 PM
willyfastz
willyfastz's Avatar
I don't recommend the LS7 clutch for any car with more than stock power. There's also a lot of post about sticking pedals with the LS7 clutch.
Old 07-23-2006, 03:00 AM
SultansDiamond
SultansDiamond's Avatar
Ranger
Ouch, I'm going in next week for H/C & LS7 clutch on my '02 C5 vert.
Will only be making around 400rwhp after the upgrades and plan to run the 1/4 mile only a couple times for curiousity and bragging rights.
Wanted to do the textrilla, but the installer feels for mostly street driving where slipping the clutch is a regular occurance racing clutches aren't the way to go.
Sound's like you rev up to over 3500 rpm then drop the hammer on launch. That's certainly aggessive driving... plus adding in 33 launches... that's some serious demands from a clutch - any clutch. Just courious, if your that serious a racer... why did you ever choose the LS7 clutch in the first place?
I've heard the pedal hang up thing is a master/slave issue... isn't it fixable?
Old 07-23-2006, 06:16 AM
Ranger
Ranger's Avatar
Originally Posted by SultansDiamond
...Sound's like you rev up to over 3500 rpm then drop the hammer on launch. That's certainly aggessive driving... plus adding in 33 launches... that's some serious demands from a clutch - any clutch. Just courious, if your that serious a racer... why did you ever choose the LS7 clutch in the first place?
I've heard the pedal hang up thing is a master/slave issue... isn't it fixable?....
Every clutch has its own characteristics. Clutches made by LUK have a tendency toward pedal issues, with the LS7 version being the worst offender.
The LS7 clutch is just the most finicky i've experienced, and it comes stock on the C6 Z06, so I didn't havve a choice.
The C5 Z06 clutches gave me 150-175 launches at rpm of 4000-5200. So the LS7 clutch is definitely weaker, proportionately.
Hope it works OK for you.
Ranger
Old 07-23-2006, 06:37 AM
WKMCD
WKMCD's Avatar
I've got about 5k on my LS7 clutch with no problems whatsoever. I'm at 460-470RWHP and drive the pi$$ out of it but no track time.
Old 07-23-2006, 06:54 AM
Ranger
Ranger's Avatar
If you ever do take your car to the drag strip and launch with that LS7 clutch, then suggest you
(1) make a very fast release of the clutch pedal, e.g. almost no slip
(2) ensure a launch rpm <3500
That doesn't make for a good 60', but it will keep the clutch from glazing and the pedal from hanging.
Ranger
Old 07-23-2006, 08:35 AM
6Speeder
6Speeder's Avatar
At your power level the Spec Stage II will be fine. I"ve run mine since 2003, including 20 or more 1/4 mile runs, with drag radials. Still works fine.
To Ls7 clutch
Quick Reply: Ls7 clutch
