How Much Nitrous Can My Motor Handle
Dig
I Have A Stock Motor, Fuel Injectors And Fuel Pump.
I Have The Zex 125 Wet Shot That I Always Use. But, I Have A Dry 150 System Coming Today.
Without Changing My Dyno Tune And Fuel System, What Combination Of The Above Systems Will Be Safe And Give Me The Best (fastest) Gains
Dig
Help
How About 75 Dry Shot And 100 Wet Shot.
With The 100 Shot Coming On At Full Throttle And The 75 Shot At 4000 Rpm's.
Or
125 Wet Shot Coming On At 3500 Rpm's And 75 Dry Shot
Coming On At 4500 Rpm's
Will I Be Able To Do Either Of The Above Combos With My Stock Motor ????
Or
This combo sounds good and would work well with stock motor. It is risky anything above 150 combined is, but go for it.
The 2nd combo is probably doable but I wouldnt spray 200 on a stock motor.
the motor can handle up to about a 150 dry and a 200 wet, seen many cars run this much nitrous on a nightly basis, i would personally not go higher than a 100 dry 150 wet kit each motor is differant keep that in mind
