Has anyone installed this intake? Bolt on 50 hp.
This thing is not cheap, but states some big claims. I was wondering if this was discussed already. I couldn't find it through the search.
I know I have a C4, just looking out for fellow enthusiasts.
http://www.nitrouswarehouse.com/ls-spyder.htm
:D
:D
Re: Has anyone installed this intake? Bolt on 50 hp. (jimbjr)
3200.!!!!! :eek: i believe mr. stewart is on crack :crazy: i'm curious to know who would give that kind of money away for an intake manifold. they would have to be :crazy:
Ive seen several of these aluminum manifolds tested. One on my car in fact. Unless this particular design is completely different than all of the others, I'd say keep your money. 3+ grand for 50 horsepower is a little extreme, even if it will make the horsepower it claims (and in my experiences it won't).
I have never seen one of these type of manifolds add power to a car. The only increases the manifold made were on nitrous applications.
[Modified by glen5839, 7:54 PM 8/23/2001]
Received 5,188 Likes
Re: Has anyone installed this intake? Bolt on 50 hp. (glen5839)
A lot for a Chevy manifold, any Chevy manifold, but compared to my friend's Anniversary Contach intake replacement at $13,000 (no mistype) WHAT A BARGAIN! I'll pass, anyway.
If the designer wants to demonstrate this 50HP gain on an independent dyno and independent heads and cam and stroker motor car maybe at a big show in front of a bunch of people and than go out and back it up on the track with at least a 3.5 to 5 mph gain in trap speed and lower the price at least 1,000.00 dollars he might sell some.
Cruise-In III Veteran
Re: Has anyone installed this intake? Bolt on 50 hp. (robsvette)
ummmm lets see here
$900 for a cat back exhaust
$12000 for a supercharger installed
$1000 for headers
$6000 for heads and cam installed
need I go on??????
Supposedly SAM Racing is trying it out. It is NOT Stewarts manifold. He has NEVER given out dyno numbers. I would try for about $1000, but.......
He needs to back up his claims and do some tests. Hogan makes similar manifolds for about $500 +/- cheaper.
Would be a nice addition to a 427 if the price was at leat 50%+ lower. :cry
Re: Has anyone installed this intake? Bolt on 50 hp. (intel55)
At $64/hp, if in factthe 50 HP claim is true I'd pay it. That's pretty cheap and easy HP. You don't even have to open the motor. I remember I paid $2400 for a variable intake on my VW Golf a few years back and I only got 15HP:eek: Has anyone phoned to see if they'll back the claims with a dyno run?
Joe
Joe
I've found that most mods that do nothing more than open up the intake a bit:
(1) Don't make nearly the HP claimed. They work. I've just never been able to verify the (overstated) claims. That goes for any/all intake mods I've seen including the cold air intakes, etc.
(2) Only increase power above about 4500 RPM. The stock system flows well enough below about 4500 RPM that you could put a manifold and ductwork the size of a 50 gallon garbage can in there and it'll still be 4500 RPM before you see any gains because below that, increases in efficiency over the stock stuff is minimal/negligible. At lower RPM, our intakes are the equivalent of running water from a garden hose through a 3 foot sewer pipe. Increasing to a 4 foot sewer pipe really isn't going to change anything. ;)
Just my experience.
Mike
Just my experience.
Mike
Re: Has anyone installed this intake? Bolt on 50 hp. (mchaney)
Bingo Mike, It also in all likely hood hurts low end Trq. where you need it most when in the real world, The street.. It should slow down intake velocity and as such hurt low end as I said, Intake velocity should not be overlooked.
You are right it 'STATES" some big claims..Sounds like a lot of :bs to me...You know anything that sounds too good to be true........ :smash:
Orlando Events Coordinator
Cruise-In II Veteran
I just spoke to this guy...he's off the wall. It does not work below 6000rpm
[Modified by Peach, 11:51 AM 8/24/2001]
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
That said, 50hp is a rediculous claim!
Like I said I have seen 3 of these type of intakes dyno'd and they actually lose hp on the dyno under all motor applications.
You don't even want to know how much torque they lost!!! :eek:
The ONLY gains were high RPM nitrous applications.
Re: Has anyone installed this intake? Bolt on 50 hp. (SDVette)
Take a look at my post http://forums.corvetteforum.com/zerothread?id=139409). This is a 98, but look at the picture of the rear of the stock air box. I don't think a 3-foot sewer pipe comes to mind!
I still think a decent intake like the Blackwing is a good investment because there is life above 4500 RPM. I just think that people overestimate the claims and not many people realize that these are high RPM mods only. Lack of benefit at lower (<4500) RPM was the reason for the sewer pipe analogy.
Mike
O.K. I'm a software guy too :rolleyes: but here's my calculation:
350 cubic inches of air are required every 2 revolutions of the engine.
That equates to .101 cubic feet every revolution, so at 3000 RPM, it's just over 300 cubic feet per minute, or 5 cubic feet per second.
Seems like a lot to be going through 4 dime-sized holes! But I'm no automotive engineer, although I did sleep at a Holiday Inn Express last night :D
Good calculations SDVette, but that is assuming that you are getting 100% volumetric efficiency. Which the way I understand it is almost impossible without forced induction.
Jerry
Jerry
I can't say for the final dyno on the SAM racing camaro, but the last one I heard (from my engine builder and former student) was it picked up about 5 RWHP on the top end...
It does look pretty trick though.
Mike
