Build sheet location
Old 04-16-2006, 11:07 AM
redjetty
redjetty's Avatar
Default Build sheet location
can someone tell me where i can find my build sheet on my 04? i read someplace in here that its found in the front re-bar??? what would that be ?,, thanks rj
Old 04-16-2006, 11:41 AM
purrvert
purrvert's Avatar
Check your glovebox.
Old 04-16-2006, 12:57 PM
wamara
wamara's Avatar
Cruise-In II Veteran
What you are referring to in the glovebox is NOT the build sheet.
redjetty,
The build sheet is a folded printer sheet in the front crossmember frame rail (which is a hollow boxed member). I think the only way you can get to it is by removing the front fascia. An easier way to obtain one (albeit not "original") is to order one from the NCM.
Old 04-16-2006, 01:15 PM
SpeedyZ
Support Corvetteforum!
SpeedyZ's Avatar
redjetty,
You are correct, you have to remove the front fascia (bumper cover) and the front bumper (foam pad) then you reach in the end of the front impact bar (front frame cross section) and pull out the sheet.
Anyone know how much the NCM charges for the sheet?
Old 04-16-2006, 02:10 PM
wamara
wamara's Avatar
I suspect the NCM's website would state the cost.
Old 04-16-2006, 06:38 PM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
I just purchased two, one for my 2000 and one for my 1985. They were $25 and $30 laminated. I can't remember which was which, but it is I believe $10 more if you are not a member of the NCM. They look terrific.
Good luck... GUSTO
Old 04-16-2006, 07:03 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
i've got a thread on this, let me find it, have pics and location
Old 04-16-2006, 07:06 PM
SteveDoten
SteveDoten's Avatar
here ya go, if you are local i'll help you remove the build sheet(takes about an hour)
http://forums.corvetteforum.com/show...highlight=ncrs
To Build sheet location
Quick Reply: Build sheet location
