Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-02-2006, 01:18 AM   #1
sr71 blackbird
Junior Member
Default Help with power antenna repair
I've searched the archives, but can't find details on repairing the power antenna (01 Convertible). The motor runs but mast stays in up position (no viagra jokes, please!).
Chuckster wrote about fixing a similar problem, but I couldn't find any details about removal of the unit to begin the repair work. Also, how will I tell if it's the "tail" that's lost it's teeth or something else?
I've replaced antenna mast "tails" before in a 90 Acura legend-- pretty easy, but getting at it was also easy.
Help please and thanks.
sr71 blackbird is offline   Reply With Quote
Old 04-02-2006, 01:30 AM   #2
dataporter
CF Senior Member
dataporter's Avatar
Take out both passenger side tail lights and the antenna is right there behind them. You have to drill out the rivets to get it apart or you can buy a new one from Fred Beans.
Click here for Google advanced search of Corvette Forum
dataporter is offline   Reply With Quote
Old 04-02-2006, 11:58 PM   #3
sr71 blackbird
Junior Member
Thanks. I successfully removed the antenna unit, drilled out the rivets, and found that the lower portion (about 5 inches) of the ribbon was broken off from the rest. That's why the antenna couldn't retract, as the remaining ribbon wasn't threaded.
I took the gears apart, rethreaded the ribbon that was left and reassembled the whole thing. Unfortunately, the antenna went up just fine, but can't retract, probably 'cause there's not enough ribbon remaining to do so properly. I'm guessing here.
Can I just buy a mast and ribbon to rethread in the motor housing, as it seems to run okay? Is that a dealer item or need I search for it elsewhere? Can I thread it without disassembly again?
Thanks in advance.
Old 04-03-2006, 02:34 PM   #4
captcruz
CF Senior Member
captcruz's Avatar
Send a message via MSN to captcruz
That would be cool if you get a chance to show us in a pic what your seeing. Words speak, but a pic is worth a thousand words
captcruz is offline   Reply With Quote
Old 04-03-2006, 02:53 PM   #5
RPOZ4Z
CF Senior Member
Cruise-In VII Veteran
RPOZ4Z's Avatar
cost me $90.00 for a new power antenna, there's no sense in trying to fix it at this point, and since it's already out you might as well just put in a brand new one and be done with it.
__________________
98 Pace Car #383 SOLD! gone but not forgotten....
73 Convertible: Perpetually in the middle of a frame off resto...
RPOZ4Z is offline   Reply With Quote
Old 04-04-2006, 12:51 AM   #6
dataporter
CF Senior Member
dataporter's Avatar
Quote:
www.fredbeansgmparts.com
BTW there is a real SR71 Blackbird sitting about three miles from my house at Castle Air Museum, Atwater, CA
Reload this Page Help with power antenna repair
Tags
2004, 90, acura, air, antenna, atwater, c3, c5, ca, corvette, fixing, legend, motor, power, repair, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
