Long tubes and Calif. emissions
Probably OK
A few vette owners, including myself, have passed
the visual part with no issues. Most smog techs
don't care about headers as long as the car passes
the sniffer. (AS IT SHOULD BE ANYWAY! )
As one of the other posts stated, get a PRE-TEST
done. Everything is off the record during a pre-test.
IF they say no problem, then proceed with the
real test.
real test.
Originally Posted by davette
Most smog techs
----------TN Stnd------------05------------06
HC--------220ppm ----------1.00----------54.02
CO--------1.20%------------0.01-----------0.39
As you can see, while it passed the local sniffer with no problem, there was a significant increase in emissions, as the factory setup emitted almost nothing. I am assuming that CA standards are much stricter, and include a NO limit.
I could give you the max numbers from my 2005 test on my 1998 vette.
However, I think the numbers get lower each year.
So, your 2002 may have to meet stricter standards than my 1998. Somebody can confirm this.
Your 54.02 HC number would barely FAIL the california
test. The cutoff for a 1998 car is 54.00, however, this
is at 15mph. At 25mph, the max HC is 37ppm.
Remember, in California, we get tested at two speeds
on a rolling meter. No more idle tests.
Yes, IF you are in a non-enhanced county, you still just have the idle test. However, 80% of californias cars are registered in enhanced areas and are subject to the rolling test. Eventually all of california will have the rolling test, as I suspect the rest of the states. California tends to set the trend in smog control. Good or Bad
I passed with my TPIS and high flow cats the guy didnt care about anything other than if it was clean or not. I just passed with my LGs too but the damn check engine light from the sensors failed the rest of it. But i got those cleared so its time to go do it again. Its just matter of finding someone who is not **** about mods and only care if the car is clean. Goodluck if u need any help finding someone that doesnt care about looks shoot me a pm.
R.
R.
Test results on my totally stock 99 coupe @ 105k mile on Nov. 05
RPM=722, %CO2 meas=14.9, %O2 meas=0.8, HC( PPM) Max=100 meas=8, CO (%) Max=1.00 meas=.05
RPM=2541, %CO2 meas=15.2, %O2 meas=0.1, HC( PPM) Max=130 meas=1, CO (%) Max=1.00 meas=.05
Received 3,043 Likes
St. Jude Donor '05
Originally Posted by dmitry_1998
my brother is big on the import scene and on his prelude he had a full exhaust system, headers, ported/bored motor. He would just take it to a test only facility, which costs around $25, if everything would be ok, he would let them smog the car. Rememeber TEST ONLY is OFF the record, so if they don't say anything you can run the smog and get your certificate. I plan to get my longtubes and dont think there will be any complications.
I personally think the no LTs law is a crock of as the exhaust doesnt know if its traveling through a manifold or not. If it passes the sniffer it shouldnt matter whats under the hood. OF course if you have LT's, you must be some street racer or hoodlum, cant have that.
Ill be putting them on my ZR1. If I have to fight it and take it to the state referee for a sticker Ill do it. Like to see their argument when I tell them those manifold/cat setups were a 1 year only piece, not avail.
Read: Not replaceable.
#33
In CalEfornia, TEST ONLY does NOT mean off the record! It means the shop does TESTs ONLY and does not do repairs. In fact the 'test only' guys can be stricter than the regular smog techs because they have nothing to gain or lose if you pass or fail, they don't even care if they get 'more' business from referrals because they have built in business from their 'test only' status. Some smog shops that do repairs will do a "pre-test" that IS off the record. If a tech fails you for the visual because you modified the factory smog equip (which includes the exhaust manifolds, etc) you aren't going to get approved at that shop until you return it to factory equip or CARB approved equip. If you fail the smog test twice, you run the risk of being fined and/or of your car being branded a gross polluter. It is very expensive to be in the smog cert business in California and if you find someone who is willing to look the other way, they are taking a tremendous risk with little to gain. So, if you want headers in CalEfornia that are not carb approved (i.e. all long tubes to my knowledge) it really boils down to, do you feel lucky?
#35
Originally Posted by C5X2C
I'm not going to worry about it until Oct 2007!
Having drivin my 99 coupe for 7 years bone stock compaired to now, Z06 suspension, LG LT, CAI and a few other mods. I'll put the stock smogable bits back on for a day to get it to pass, it will be worth it cause I'm lovin the way it runs now.
#36
Glad I live in NV!
Originally Posted by RstyNutz
Wish I had seen this before I got my shorties, that is a great concept..let then burn in and maynot be spotted by the smog tech...
So, the "shorties" are CARB certified and would pass a smog test?
We do have to pass a smog test in Reno and Las Vegas...its pretty simple with the sniffer and very little inspection!
However, as things change in CA, they tend to follow it here in NV!
Sully
