Started installation of C6 Z06 brakes
Last week, I received the C6 Z06 brakes package from Fred Bean. Over the weekend, I began the installation on my 98 coupe with Fikse FM5 18"X9.5 front & 18X10.5 rear. The rear wheels fit over the rear brakes with no problem. The front will require a 1/4" spacer. I will be ordering the spacers from Fikse. The stock brake hoses will not fit, they are too short & they are obstructed by the top caliper bolts. I bought S/S Goodridge hoses that are a little longer than the stock hoses, but on the 98 coupe the hose blocks that attach to the calipers must be modify at one of the edges so that they tilt in order to bypass the top caliper bolts. The 1st picture shows the front wheel mounted to the car with 3 washers on each bolt to determine the size of the spacer that will be needed. Pictures shown below..........
wow, looks great! How much heavier is the C6Z set up vs C5Z? I think Id like to run chrome 18x10.5 C5Z rims all the way around and those brakes if theyre not too heavy. If they dont dramatically reduce braking distance, Im sticking with the C5 set up.
Its when you are on track repeatedly stopping that bigger, more heat tolerant brakes tend to help. The c6 z06 brakes currently have some issues for that kind of usage though:
quoting from the z06vette.com forum
"The C6 Z06 PBR brake system is a direct bolt on with 1/4" spacers for clearance needed on some wheels. You will of course need 18" wheels to clear the front 6 piston calipers.
However there are problems with the system:
- There are NO right side rotors available. (The cars from the factory come with left sided rotors mounted backwards on the right) The rotors have directional cooling vanes...so the ones on the right are backwards.
( This is not a big deal on a street driven C6 Z06 because Chevy increased the cooling duct flow 4X) However the C5 Z06 does not have this benefit...therefore duct extensions and spindel ducts MUST be used other wise the right side rotor will overheat.
- Despite being drilled the rotors are still too heavy at 25# each
- Being drilled. the rotors are still prone to crack at track events.
- Pads are listed but are currently back ordered. ( Some guys that have tracked their new C6 Z06's have had to park their cars waiting for new pads.)
- Pads are extremely thin and wear out quickly, especially on the track
- Pads are the same front and rear , front kit has 12 pads, rear kit has 8 pads. Kits are priced the same at $337 each...go figure.
- There are no race compound pads yet available. There are some aftermarket Co.'s working on this but PBR is resistant and is threatening a law suit saying they have propriotory rights. Which is probably BS. If you change something (like the pad compound), the patent does'nt apply.
- Some racers have experienced top to bottom pad taper as the cliper piston shim only contacts half the pad.
If PBR was smart they would immediately supply:
- a correct right side rotor
- race compound pads (thicker)
- a slotted, 2 piece, light weight hatted rotor
Until these problems are solved I don't even recommend upgrading these for track use, or as a replacement on the C5 Z06
Instead I recommend using either Stop Tech or Wilwood replacement rotors or system replacement.
Originally Posted by jmautox
Did you manage to find proper right side rotors?
I do not plan to track my car. I usually go to the drag strip about zero to twice a year for a max of about 3 trial runs per event.
I did not weigh the Z06 package before installation, but it is considerably heavier than stock. As you know the calipers & rotors are bigger & beefier. The extra weight is not an issue for me because with the maggie I barely have traction now.
Pimpalicious.
Now I've seen it all, fake caliper covers ! Let's see, we could get fake engine covers ( that say 427 cu in), fake HID lights, fake superchargers, there is NO END to the possibilities !
They want to make sure that you are fully satisfy. How can you go wrong?
You might consider a set of these instead:
http://cgi.ebay.com/Brembo-R34-Front...QQcmdZViewItem
The C6 Z06 brake system looks good and they are cheap. Thats the only upside to this brake system. For me the downside outweighs the upside and I wouldnt put this setup on my car.
Is there also issues with pedal travel and needing to upgrade the brake master on the C5 in order for this system to work as the pads wear?
ching... ching...
VR
ching... ching...
VR
Those brakes look insane!
Somethings wrong here - a $75,000 product with backward brake rotors... c'mon GM wtf???
I know the company that makes the polished C6 wheels for GM was giving them problems - hopefully this is just because of whatever company supplies the rotors?
