Window want go down!
I just had this same problem. My problem was there is a short between door and car where the door wires run through the accordion tube. But it took me a few days to find that out. From the research I did these are the common problems. First off you know check your fuses. I removed the door panel and checked the door control module and door control switch with a test light using a wiring schematic in a manual I have. You might be able to find one on the internet. Mine were showing they were good. Last I would do is check all your grounds on the body. If that doesnt fix it then good luck. It was a PITA! to figure it out.
Here's a good link to remove door panels: http://www.vetteessentials.com/instr...or_handle.html
I also read to try slamming the door while you press the button down
Originally Posted by PaPaChoc
My drivers side window want go down and the driver door lock (push button) quit a while back. What’s usually the prognosis?
Anyway I also had the wires between the door and the jamb get a break.
Originally Posted by C5forFun
PaPaChoc, are you from KY? I know a lady who uses "want" in place of "won't".
Also, I have the same problem as you did. Did you have to replace the harness? I just found the short, but haven't had time to fix it. Let me know what you did to fix it. Thanks, Jeremy
I had extended warranty so they replaced the harness.
