Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-08-2006, 08:08 PM   #1
STLBLUES
CF Senior Member
St. Jude Donor '09
STLBLUES's Avatar
Default Crank pulley/balancer bolt torque specs?
Ok my balancer slipped and moved out after a cam swap. I have the rack moved out of the way and I am ready to wrench. I need to know what the torque spec is. I have seen 200 and 250 ft lbs listed. After you torque the bolt to 250 why remove it and use a new bolt?
I followed ls1howto and torqued to 200 then installed a new bolt and torqued it to 37lbs and then marked it and turned it another 140deg. My only mistake was no locktite because the new bolt looked like it had some on it from GM.
Does the balancer spin on the crank and back the bolt out? I know someone will mention crank pinning or ARP bolt. I also know tons of people do not have this problem after cam swaps using the stock bolt only. Does anyone have a better way to go at this? Or should I just repeat my steps and loctite it?
Thanks Steve
STLBLUES is offline   Reply With Quote
Old 03-08-2006, 09:40 PM   #2
gonbad
CF Senior Member
gonbad's Avatar
You torque the balancer back on to 250ft lbs. Then use a new bolt to 37lbs then twist 140 degrees.
Yes the balancer can spin on the crank and cause the bolt to back out.
Did you re-use your balancer? I think this is the main problem. Re-using a balancer that has already been stretched onto the crank once will not hold the same again when stretched over the snout. I would always use a new balancer whether it was stock or not. Otherwise I would pin crank. Actually if I did this again I would key the crank anyways.
I feel your pain. My stock balancer failed in the rubber section and slid into the front engine cover. It did a lot of damage. While I was in there fixing it I did a cam swap. Getting everything out of the way then fighting with the bolt was a real experience.
__________________
Gonbad
98 6spd, Silver coupe, Firethorn, F45, R8C, Loaded.
Mods: F4 Cam 226/226 .575/.575 LSA 112, UD Pulley, 918 Springs, Ti Retainers, Push Rods, JWIS Chain, LS6 Oil Pump, MSD Wires, NGK TR55, Stinger-R Intake, Alpine alarm. Z51 sways, Slotted Rotors, Hawk Pads, Bias Spring, SS Brake Lines, QF5, Kuhmo's,
357 RWHP and 345 RWTQ
gonbad is offline   Reply With Quote
Old 03-08-2006, 09:49 PM   #3
gonbad
CF Senior Member
gonbad's Avatar
You have to use a new bolt because it is a torque to yield bolt.
Old 03-09-2006, 12:13 AM   #4
jhong321
CF Senior Member
jhong321's Avatar
The crank bolt is suppose to strech when you torque it down. That is why you use the old bolt first. Trust me it is worth the time and money to use a old bolt. The previous owner of my car did that and it end up cost me a new motor
jhong321 is offline   Reply With Quote
Old 03-09-2006, 01:24 AM   #5
ecudooberhead
CF Senior Member
ecudooberhead's Avatar
Send a message via AIM to ecudooberhead
My UD pulley bolt backed out twice this week- yesterday it was on the dyno when it happened. Turns out you can only use those stretch bolts once
like everyone else said, tq the crap out of the original bolt to get that pulley on good and tight, then pull teh bolt, put the new stretch bolt on (with loctite!!) and tq to 37ft/lbs- then another 140degrees, and hopefully it'll stay on.
Good luck getting that steering rack out of the way- its a real PITA!
ecudooberhead is offline   Reply With Quote
Old 03-09-2006, 03:18 AM   #6
AMERICANMUSL
CF Senior Member
AMERICANMUSL's Avatar
Thanks Steve
Been through this twice thanks to ####...pin that sucker, use new bolt and balancer to recomended specs w/red lock tight.
AMERICANMUSL is offline   Reply With Quote
Old 03-09-2006, 05:56 PM   #7
STLBLUES
CF Senior Member
St. Jude Donor '09
STLBLUES's Avatar
Ok a new balancer will be purchased this week. I do not want a underdrive because I have enough hp as it is. I have the rack moved and a new bolt in hand. I think the new balancer and locktite will get me back on the road.
Anyone make a stock size balancer thats better than gms?
Thanks, Steve
Old 03-09-2006, 07:31 PM   #8
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
Quote:
I installed the ATI, and the interference called for is 0.0007 - 0.0009". I don't know what the stock balancer interference fit is, but I personally believe that they should not be re-used either.
vettenuts is offline   Reply With Quote
Old 03-09-2006, 07:38 PM   #9
mph1972
CF Senior Member
Cruise-In VIII Veteran
St. Jude Donor '07
Support Corvetteforum!
mph1972's Avatar
Send a message via Yahoo to mph1972
Well said!
mph1972 is offline   Reply With Quote
Old 03-09-2006, 08:59 PM   #10
gonbad
CF Senior Member
gonbad's Avatar
Thanks, Steve
ATI makes a stock diameter balancer. Pricey bastard though if I remember correctly.
Old 03-09-2006, 09:32 PM   #11
kdub1
CF Senior Member
kdub1's Avatar
Seriously guys, you replace the balancer just because you remove it? Must be something exclusive to a Gen III or newer. I've been working on SB Chevys for 30 years and never heard of having to do that. If you remove it with a puller, what damage have you done?
kdub1 is offline   Reply With Quote
Old 03-09-2006, 10:25 PM   #12
STLBLUES
CF Senior Member
St. Jude Donor '09
STLBLUES's Avatar
Quote:
The balancer is press fit with no key way. The only thing that holds it on is the bolt and a tight tolerance. I wish gm would have made it just like the old small blocks.
Old 03-10-2006, 03:41 AM   #13
AMERICANMUSL
CF Senior Member
And how!
Old 03-10-2006, 08:25 AM   #14
kdub1
CF Senior Member
kdub1's Avatar
No keyway? No wonder guys are pinning the balancers. Thanks for the info.
Reload this Page Crank pulley/balancer bolt torque specs?
Tags
94, arp, balancer, bolt, corvette, crank, crankshaft, gen, gm, iii, ls1, pulley, spec, specs, torque
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 89 09-24-2013 01:59 PM
Crank bolt issue - WHAT is the cause? WHY does the bolt loosen? Vet C6 Corvette General Discussion 52 01-24-2010 08:15 AM
DTE LS2 Engine Conversion Performance Upgrade Package- C5 Corvette DTE Powertrain C5 Tech 125 10-07-2005 07:36 PM
Crank bolt happened at 65 MPH!!! VNAMVET C6 Tech/Performance 102 05-06-2005 07:57 PM
any1 know how to install the ati super damper???? pdd000 C5 Tech 10 01-06-2005 07:51 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
