Column lock letter from GM[merged]
Old 02-08-2006, 02:09 PM
2KFRC5
2KFRC5's Avatar
Default Column lock letter from GM[merged]
It looks like GM has abandoned the "electronic column lock" with the following Special Policy Adjustment notice:
Subject: GMP06-029 - 05081 Special Policy Adjustment - Electronic Column Lock System
Supposedly, GM is sending notices to owners starting Feb 15. In the notice GM is directing dealers to remove at no cost to the owner the column lock plate on most '97-'04 Corvettes
Anyone know where we can get a copy of this, or more about it?
From a reliable source - - - -
Old 02-08-2006, 02:21 PM
dreamscometrue
dreamscometrue's Avatar
Old 02-08-2006, 02:36 PM
JeffC5
JeffC5's Avatar
Location: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
http://forums.corvetteforum.com/show...4&forum_id=103
jeff
Old 02-08-2006, 02:52 PM
2KFRC5
2KFRC5's Avatar
http://www.c5forum.com/cgi-bin/ultim...68.html#000000
MODELS:
1997-2004 CHEVROLET CORVETTE EQUIPPED WITH A MANUAL TRANSMISSION
1997-2000 CHEVROLET CORVETTE EQUIPPED WITH AUTOMATIC TRANSMISSION
2001-2004 CHEVROLET CORVETTE EQUIPPED WITH AUTOMATIC TRANSMISSION – EUROPEAN EXPORT
VEHICLES ONLY
DESCRIPTION:
PRODUCT SAFETY #04006C
DATED: FEBRUARY 8, 2006
IMPORTANT:
THIS BULLETIN CANCELS AND REPLACES BULLETIN 04006B, ISSUED NOVEMBER 2004. THE SERVICE PROCEDURE FOR U.S. VEHICLES EQUIPPED WITH A MANUAL TRANSMISSION HAS BEEN REVISED. PLEASE REVIEW THIS NEW INFORMATION IMMEDIATELY.
ALL COPIES OF BULLETIN 04006B SHOULD BE DESTROYED.
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 1997-2004 model year Chevrolet Corvette vehicles. When you remove the ignition key, the electronic column lock (ECL) system prevents turning of the steering wheel. When the vehicle is started, it unlocks the steering. Two conditions can prevent steering while the vehicle is moving:
1. The vehicle is designed so that if the column fails to unlock when the vehicle is started, the fuel supply will be shut off if the driver tries to move the vehicle. If voltage at the powertrain control module is low or interrupted, however, the fuel shut off may not occur and the vehicle can be accelerated while the steering is locked.
2. During quick cranks, the ECL lock pin may not withdraw fully and, in vehicles where there is abnormally low clearance to the lock plate, there may be contact between the pin and lock plate. This can cause a noise or ratcheting when the steering wheel is turned or, if there is insufficient clearance, the steering wheel cannot be turned.
If one of these conditions occurs, a crash could occur without warning.
CORRECTION:
Dealers are to remove the column lock plate on U.S. and Canadian vehicles equipped with an automatic transmission and U.S. vehicles equipped with a manual transmission. After the service correction, the steering column will no longer lock when the key is removed.
On Canadian and export vehicles equipped with a manual transmission, and export vehicles equipped with an automatic transmission, Dealers are to 1) reprogram the PCM, and 2) verify there is adequate lock plate clearance and, if necessary, replace the lock plate. After the service correction, the steering column will continue to lock when the key is removed.
Refer to the Product Safety Bulletin #04006C for further information.
EFFECTIVE DATE:
Owner mailing is scheduled to begin February 15, 2006.
GENERAL INFORMATION:
Parts required to complete this recall are to be obtained from General Motors Service Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO – Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO – Customer Special Order.
The Parts list follows:
Part Number Description Quantity/Vehicle
89023816 Harness Kit, Strg Whl Theft Dtrnt Lk Shorting (US manuals and all automatics except export vehicles) 1
88952428 Wire Kit, Strg Whl Theft Dtrnt Lk (1998-2000 Canadian and export manuals & export automatics) 1 (If Req'd)
26056108 Nut, Strg Whl 1 (If Req'd)
26094767 Plate, Strg Shf Lk (Canadian manuals) 1 (If Req'd)
88964588 Plate, Strg Shf Lk (Export vehicles) 1 (If Req'd)
05694191 Ring, Strg Shf Lk Plt Ret 1 (If
Last edited by 2KFRC5; 02-08-2006 at 02:58 PM. Reason: Added text from C5forum.com
Old 02-08-2006, 02:53 PM
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
keeping my eyes and ears open on this post!!!!
Old 02-08-2006, 02:58 PM
MR1911
MR1911's Avatar
Me too
Old 02-08-2006, 03:23 PM
DngrZne
DngrZne's Avatar
Maybe procrastinating buying the CLB will save me $50 afterall
Old 02-08-2006, 03:48 PM
MGorman
MGorman's Avatar
Wow after all these years, finally some new and encouraging news.
Why did they suddenly decide to do the right thing? This is so unlike GM.
Old 02-08-2006, 03:49 PM
wstory1
wstory1's Avatar
Old 02-08-2006, 04:50 PM
Ginzo
Ginzo's Avatar
Me too! Actually I was going to let it lock up one time before I installed the CLB.
Old 02-08-2006, 05:00 PM
TEXHAWK0
TEXHAWK0's Avatar
CORRECTION:
Dealers are to remove the column lock plate on U.S. vehicles equipped with a manual transmission. After the service correction, the steering column will no longer lock when the key is removed.
(If
This is exactly what I did on my 04 Z06 two years ago, except I went one step further and installed the GM Harness K wiring harness.
If GM only removes the lockplate, that still just solves the problem of the column locking. If the actuator is still in the circuit, with no relay harness, I think if the actuator fails, the BCM will still shut off the fuel where the car is undriveable.
Old 02-08-2006, 10:30 PM
Cscokd
Cscokd's Avatar
I'd love to have them remove my lock plate, but I won't let them touch my PCM
Old 02-08-2006, 11:15 PM
40thAnniversary
40thAnniversary's Avatar
what changed from the 2000 to 2001 automatic that made it exempt?
Old 02-08-2006, 11:18 PM
idiedtrying
idiedtrying's Avatar
is this even if you bought the car used?? GM will still fix it>?
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Word. From Ken Fitchner Chevrolet.
http://forums.corvetteforum.com/show...post1553930524
Old 02-08-2006, 11:26 PM
Tourmgr1
Tourmgr1's Avatar
I have already had the PCM reprogrammed and installed the CL fix .....my car will NEVER be at a dealers shop. Take it at your own peril ....the dealers will be looking forward to this recall .....a wonderful chance to screw more money out of the uninformed with unecessary repairs.
Old 02-09-2006, 07:53 AM
TOPGUN9
TOPGUN9's Avatar
I installed the CLB back in 1999 when I bought my coupe new. Never looked back; probably the best $50.00 I ever spent.
To Column lock letter from GM[merged]
Old 02-09-2006, 08:56 AM
mrm1149
mrm1149's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
My perception verbatim...any further views? I will do the clb which should take care of the actuator being knocked out of the picture.
I have had 2 defective k harnesses which have been removed. So...with the plate and clb I see no fuel cutoff problem occuring?? A4 automatic........
MIKE
Old 02-09-2006, 08:58 AM
litnrod
litnrod's Avatar
Well...here is my two cents...and I am not happy.
I own a 99 mn6.
In Mar 05...The CL locked up on me as I was leaving a restaurant. Car undriveable. Had to leave it there, overnight. Rented a car. The next morning I had it towed to the Chevy dealer. All in all I spent $900 dollars getting this thing fixed, because the column lock was not covered in the first recall. And the first recall was already performed.
I argued and argued with GM...they kept putting me off, until nonetheless I got frustrated and gave up...I imagine this is what good customer service is all about. Make them wait until they give up or it costs us money (our time).
Now, they 1 year later, when they knew there was a problem for the past 8 years.
Hmmmm...is it worth my effort to pursue this yet again?
Is my column lock going to fail?
Do I need to get the new recall done?
Thanks for any input.
If they hear you before they see you, it is loud enough.
1999 Torch Red C5 Coupe
K & N Dual Air intake, B&B Bullet, Michelin A/S Pilot Sport ZP, Black Z06 Rims
Old 02-09-2006, 09:03 AM
mrm1149
mrm1149's Avatar
I would sure as h*ll pursue some sort of reimbursement as I'm sure there was plenty of profit $ in the repair you paid for originally. Years ago I had a similar scenario with a fo*d fuel pump..........
Quick Reply: Column lock letter from GM[merged]
