Code B0-RFA C2120 ???? 99 C5 Diagnostic
Going through my codes I discovered a code that I could not identify on Corvette Doc. I hope I did not look right at it and missed. But has anyone seen this code before?? Will you please help me out?
Thank you very much
Thank you very much
doesn't look like a trouble code, you missed something. But I will look later to make sure something seems like I have seen it before.
Thanks alot this explains the tire pressure warnings. Shouldnt the active handling have a code as well if the warning is always being displayed? The check engine light and warning is on as well would it be shown under the codes somwhere as well?? I had a total of 7 codes 3 for air bags 3 for the air conditioning and now the 1 for the tire sensors. Would these other 6 make the engine light come on?
Veteran
2120 indicates the receiver has lost the signal from the sensor(s).
It could be a potential problem or just a glitch.
You should clear the code and reprogram the sensors and see if it comes back.
Here's the link to program the sensors:
https://www.corvetteforum.com/techti...D=77&TopicID=1
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Active Handling has nothing whatsoever to do with the tire pressure system.
The check engine light is displayed whenever an emissions-related trouble code is set....these will almost always be in the 10-PCM section.
List all your codes and we can probably figure what tripped the CE light.
The codes that showed current were B0017/B0026/B0051. Air bag codes
P0645/P0480/P1546. Air Conditioning Codes
And the B0-RFA C2120 Tire sensor codes.
Would any of these cause the service engine light????
This what I found
B0-RFA - Remote Function Actuation
C2120 TPM System Malfunction (No Sensors Received)
If all those codes coming up sounds like you are having a control module going bad on you that feeds all these circuits, if there all on the same Body control module. And as I was looking today there's like about 9 body control modules on the vettes, plus your PCM.
St. Jude Donor '03
those sensor's on the wheels an't like your ABS stuff now. I can't believe how many problems people are dealing with on these Corvette's. Okay I can, I guess thats why GM is going under.
This what I found
there is only 1 bcm.there is a tac,pcm,rfa,ebcm,sdm,ldcm,rdcm,hvac[dual zone],rtd. the tpm faults are because i think he swapped over wheels. the 2 a/c faults are for system performance and a compressor clutch circuit[may be out of refridgerant or a default because there is a cooling fan problem].
the faults are NOT a bad control module[highly unlikely].the tpm system is built into the rfa module.the airbag module[sdm]is a stand alone unit,the pcm is another.more than likely his glitches are all minor problems. has nothing to do with GM's profit problems.that is a whole other ball game. on low speed the fans run in a series circuit[one fan gets its ground by going through the other]and on high speed they switch over to a parrallel circuit.that's why there are 3 fan relays.if the fans go straight to high without seeing low first,the pcm knows something is wrong[this was basically a short cooling fan lesson].
the airbag faults are because the car has been in a wreck or THINKS it's been in a wreck[51 is deployment commanded.the other 2 are for the front airbag deployment circuits first stage.gm uses 2 stages depending on speed,impact,rate of decel,etc.].this one may be a bad sdm if the car hasn't been wrecked.if the bags haven't gone off,the unit is bad[this is common].but with the front bag faults,the car has probably been in a accident.JMO
