Will 100 shot TNT NOS be more reliable on stock engine or with one with heads, cam, etc.
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Its just a matter of when that I pull the trigger on 1oo shot TNT wet NO2 kit. My car has cartek stage II heads and cam, headers, etc. With my significant upperhalf engine mods will NO2 be more safe with my engine or is there extra risks giving my mods and close to 400 rwhp. Or is NO2 safer in basically stock LS1 without heads, cam etc. or does it make no difference.
Also, my biggest concern is not blowing up my engine with NO2 costing me thousands more than I've already spent and given this what other changes have to be made to be as safe as I can be with NO2 (other than all the NO2 safety bells and whistles) to insured the most reliability. i.e fuel pump upgrade, etc.
Thansk,
Nitrovette
Thansk,
Nitrovette
Re: Will 100 shot TNT NOS be more reliable on stock engine
Nitrovette, I have gone through 40 bottles on my heads/cam car @ 150 hp shot, I did have a broken valve spring once. i have been told that your just pushing more hp (in our case 500+) through a basicly stock engine.
Well, I am no expert but if I had to I'd say................... the 100 shot would be safer on a stock car. I say this because with the H&C you are already making more power than the stocker. The H&C has added some stress to the bottom end and the 100 shot may push it over the edge. Lots are doing it though with no problems. I have a stock motor and I can't muster the b@lls to put it on my car............
Joe
Joe
Nitrovette, I have gone through 40 bottles on my heads/cam car @ 150 hp shot, I did have a broken valve spring once. i have been told that your just pushing more hp (in our case 500+) through a basicly stock engine. :cheers:
getting power hungry AGAIN!!! :D me too! going to 3:42's wed.!!!
you certainly have the right tranny to handle the power. i have also heard from many juice users that they have had no problems with good installers. i don't know any in your area but cartek has done many systems with no problems. costly but safe. :D
also i think our set-up would handle NOS better than a stock C5 due to better intake and exhaust
Cruise-In II Veteran
Cruise-In III Veteran
I'd just start off with the 75 shot.The TNT kits are rated at rear wheel horse power.The others are crank HP.
Re: Will 100 shot TNT NOS be more reliable on stock engine or with one with heads, cam, etc.
Think about it logically.
On a stock motor, you add a 100 shot.
Your making about 400 rwhp which is roughly equal to a heads and cam setup.
Fundamentally an engine is an air pump. The faster you move air in, and out, the more power you make. The power is obviously created from the a/f mixutre forcing the piston down more violently.
So one could assume that the force pushing a piston down with heads/cam at 400rwhp is the same force when pushing the piston down with a 100 shot on a stock motor.
Not necessarily. Since RPM is a hugh factor in how and where power is developed, a heads cam setup will have less of a dramtic impact then shooting an equivalent amount of power in there with nitrous. The issue with engine failure when using nitrous comes most always at low rpm. At low RPM an engine is not pumping efficiently and that rapid shot of power from nitrous takes its toll on the slowly moving engine. With heads and cam, the power is developed more smoothly and cleanly.
Its somewhat anagolous to revving an engine at idle to 6000 RPM, or doing it smoothly under a load.
If I touch my my fist on your face with my arm cocked (heads/cam), and then thrust through you, Im gonna push you hard and down to the ground if your unaware, but Im probably not gonna hurt much. If I **** my arm and punch you from a distance (nitrous), your face is going to break from the shutter.
Now combine nitrous with heads and cam, and the initial force will not be that dramtically different than on a stock motor. Its all relative to rpm and how the engine is loaded. Nitrous on any motor setup gets safer as RPMs increase, and the load develops.
Now this is all my opinion, from what I have seen, and done. Take it or leave it. :jester
[Modified by kewlbrz, 9:28 PM 8/6/2001]
Nice post kewlbrz. I agree with you. Another good reason not to spray below 3000rpm and unless WOT.
Re: (Slammed Vette)
I agree with slammed vette about starting at a smaller shot and working your way up.
Regarding only TNT's hp to the rear wheels: My NX setup gives me the advertised hp based on the jets/pills chosen at the rear wheels also.
Slammed Vette
NX kits are rated at rear wheels also.
NitroVette
If you are looking for safety. I would go with a N20 kit that allows you to mount solenoids in a cool spot. Solenoid failure is your major concern, and heat can cause solenoid failure with seals.
Also include RPM window switch and electronic activation switch for your install.
NitroVette
Re: Will 100 shot TNT NOS be more reliable on stock engine or with one with heads, (kewlbrz)
...If I touch my my fist on your face with my arm cocked (heads/cam), and then thrust through you, Im gonna push you hard and down to the ground if your unaware, but Im probably not gonna hurt much. If I **** my arm and punch you from a distance (nitrous), your face is going to break from the shutter....
Re: Will 100 shot TNT NOS be more reliable on stock engine or with one with heads, (cosmosm3)
Now that was funny. :cheers:
Low RPMs all for more time to fill the cylinder completely. At 2000 RPMs you have all the time in the world for the nitrous to fill the cylinder where as at 6500 RPMs it has less than 1/3 the time... thus lower cylinder pressures on every stroke.
Tim
Tim
