Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-01-2005, 11:57 PM   #1
cheemsaf
CF Senior Member
cheemsaf's Avatar
Send a message via AIM to cheemsaf
Default Fuel Shutoff Switch
Anyone know of, or put in, a fuel shutoff switch? I was thinking about putting one in, in addition to and independent of the theft deterent system. I'd imagine it'd be quite simple if you knew which wire gave power to the fuel pump. Put a switch in, so whenever you leave the car, flip the switch, and power to the pump is interuppted if someone tries to start the car without turning it back on. What do ya guys think? Anyone know which wire to go after?
cheemsaf is offline   Reply With Quote
Old 12-03-2005, 10:22 PM   #2
c5wolf
CF Senior Member
c5wolf's Avatar
ttt
c5wolf is offline   Reply With Quote
Old 12-03-2005, 10:34 PM   #3
screw991le
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Send a message via MSN to screw991le
Just make one of these wires in the PCM boxes switched
Box #1
19 PNK 239 PCM Ignition Supply
Box #2
9 DK GRN/WHT 465 Fuel Pump Relay Control
Here are the PCM PIN #s
http://www.ls2.com/boggs/torques/2000vettepcm.htm
screw991le is offline   Reply With Quote
Old 12-04-2005, 09:13 AM   #4
BiggieBoy
CF Senior Member
BiggieBoy's Avatar
If they want your car, they'll simply flat bed it away.....
BiggieBoy is offline   Reply With Quote
Old 12-04-2005, 08:23 PM   #5
DPG
CF Senior Member
St. Jude Donor '06
DPG's Avatar
Quote:
tru, but hopefully it will take em just long enough for some one to notice
DPG is offline   Reply With Quote
Old 12-05-2005, 01:30 AM   #6
allmee
CF Senior Member
allmee's Avatar
Default Kill switch
I think it is a better and safer idea to use a kill switch hooked up into the clutch starting switch wiring. They won't even be able to crank the motor!! I've done them in many of my cars and they are great.
allmee is offline   Reply With Quote
Old 12-05-2005, 02:35 AM   #7
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
Send a message via AIM to diviniti
Like said above, it would be better to put a switch inline for the ignition.
If for some reason someone tried to start your car, and you have a fuel cutoff switch, it may be possible that the injectors would get damaged or fail completely without fuel running through them.
diviniti is offline   Reply With Quote
Old 12-05-2005, 02:55 AM   #8
cheemsaf
CF Senior Member
cheemsaf's Avatar
Quote:
How do you go about putting a "kill switch" in the clutch? Not too familar with that wiring...suggestions on where to hide the switch?
BiggieBoy: Yes, it's true, if they want it they'll get it one way or another (a pro that is)...if they bring a flat bed for it...that's what insurance is for. If they're just some punk teen; then maybe something small as this may work, or just frustrate them enough to move on.
Screw991le: Thanks for the pin #'s. This sounds duable. Where'd you hide the sw?
I've also been told to put a reset relay in parallel with the battery, so if someone were to disconnect and reconnect the batt, then the relay would open the circuit, and the car would be dead. The relay, of course, would be very well hidden somewhere as well.
Old 12-05-2005, 02:59 AM   #9
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
The clutch switch is behind the clutch pedal. Just get a toggle switch or push button switch that is a cutoff switch, only has 2 prongs. cut the wire behind the clutch switch run a wire from the wire section that you just cut, from the closest to the clutch switch, to one part of the cutoff switch, then run another wire from the other clutch wire to the other terminal of the cutoff switch. I would suggest hiding it some where other than under the dash, in the glove box, in teh center console, under the drivers seat.. theifs are smart to kill switches of any type and usually take the time to search for them quickly.
Old 12-05-2005, 07:22 PM   #10
cheemsaf
CF Senior Member
cheemsaf's Avatar
Quote:
Which wire do I cut??? There are 2 wires: ones purple, the other's white. I'm assuming the clutch switch is just a 2 way momentary switch; in which case it wouldn't matter which wire I cut. See picture below....ignore the red wire (that's the "go" wire for my NX kit) In the pic, I disconnected the plug for the clutch switch and am pointing to the 2 wires...just not sure which one to cut.
[IMG]C:\pict\Camera\picture082[/IMG]
Click the image to open in full size.
Reload this Page Fuel Shutoff Switch
Tags
03, 1984, 2004, 88, button, c5, corvette, cutoff, fuel, reset, resetting, shut, shutoff, switch, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
