Z06 MAF on regular Vette?
Former Vendor
I know the plugs are different, but can the Z06 MAF be converted to work on the regular Corvettes?
I have access to a free Z06 maf if it is relatively easy to convert over.
St. Jude Donor '07-'08
the plugs are different becasue the z06 MAF has the temp sensor built in, where as your temp sensor in in the air bridge. As far as how to wire it in i have never taken a close look. At a minimum you would need the z06 pigtail to plug in. Lot more hassle then it is worth imo.
Originally Posted by Gordy M
Unless you added H/C, boosted, or FI, its a waste of time.
Former Vendor
I was going to change it when I do my additional work.
Either going with a FI setup from Andy at A&A or with the G5X3, setup. So the car will be getting a tune wither way.
Would it be worth it then?
If so, what all would be needed to make it work?
Check C5 MAF conversion
