2004 cam specs?
Old 10-30-2005, 08:26 PM
PatsLs1vette
PatsLs1vette's Avatar
Default 2004 cam specs?
Im looking for the cam specs on the 2004 c5,ive found 97-03 but no 04,thanks for the help
Old 10-30-2005, 08:52 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
I have a 2004 C5 LS1 cam that I pulled with only 500 miles on it before installing a larger cam. I can sell/ship it to you cheap if you're interested.
Old 10-31-2005, 06:42 AM
PatsLs1vette
I have the cam already just trying to find out what the dur. and lift was.Putting together a ls1 for my c3.Thanks for the offer.
Old 10-31-2005, 07:07 AM
C5XTASY
C5XTASY's Avatar
Here you go:
1997-1999 ls1 y-car .479/.472 207-199dur 117 lsa
2000 ls1 y-car .500/.500 209-198dur 115.5 lsa
2001-2004 ls1 y-car .479/.467 207-196dur 116 lsa
2001 ls6 y-car .525/.525 211-204dur 116lsa
2002-2004 ls6 y-car .551/555 217-204dur 117.5lsa
Ed
Old 10-31-2005, 07:39 AM
PatsLs1vette
hey thanks ed,well that tells me im looking for a cam for this build up now,thanks again.
Old 10-31-2005, 09:03 AM
C5XTASY
C5XTASY's Avatar
You're welcome. If you want to stay with a stock cam, I have a 2000 that I don't need anymore (had H/C installed) and will sell cheap. It has 25K on it and is perfect. It's the strongest of the stock LS1 cams. Just thought I'd toss that out there in case you may be interested and are doing your own work. In any event, good luck to you!
Ed
Old 10-31-2005, 12:39 PM
carnut108
carnut108's Avatar
What is a Y-car?
Old 10-31-2005, 12:42 PM
PatsLs1vette
y car is corvette
f body is firebird camaro
let me think about c5x i might go bigger if im gone to do it.
Old 10-31-2005, 12:55 PM
carnut108
carnut108's Avatar
Does the LS6 engine come only in the Zo6 2002/2004
Old 10-31-2005, 01:29 PM
C5XTASY
C5XTASY's Avatar
Take a look at my post. There was a 2001 Z06, also. However, power was 385hp, vs 405, and the cam and heads were different.
Ed
Old 10-31-2005, 11:37 PM
carnut108
carnut108's Avatar
Old 01-28-2014, 07:57 PM
wmjosjr
wmjosjr's Avatar
Originally Posted by C5XTASY
Here you go:
Ed
Hi,
If you don't mind I need a little info myself. I have 2004 Z06, I would like to know my cam specs, as well as my head specs. I'm looking to do a head & cam swap, I don't know which way to go. I want to swap the cam, and do springs retainers, rockers push rods lifters etc. on my stock heads. Or do cam, and CNC, port and polish Etc. on the stock heads. Or just do AFR heads, and matching cam.
If you have time I would appreciate your opinion.
Thank you,
Bill
Old 01-28-2014, 09:09 PM
racebum
racebum's Avatar
Originally Posted by wmjosjr
Hi Ed,
Thank you,
Bill
you need to mention how much whp you want to make, will it be street driven or just the strip, do you have emissions testing
details like that are necessary for any informed opinion
02-04 z06 use the same cam and all years used 243 casting heads which carried over to the 05-07 ls2
Old 01-29-2014, 09:28 AM
wmjosjr
wmjosjr's Avatar
Thanks for the reply,
I would like to be in the 450 area, at the rear wheels. I'll be driving mostly in the streets, very little strip. I'm not sure what you mean about emissions testing. I'm in New Jersey, I would like to pass emissions, if that is what you mean?
Thanks,
To 2004 cam specs?
Quick Reply: 2004 cam specs?
