6 Speed transmission Rebuild
Old 10-17-2005, 01:51 AM
clone477
clone477's Avatar
Default 6 Speed transmission Rebuild
Hey guys this is a repost, I wasnt getting very many replies under the general section, try my luck here.
Just recently I noticed that my 2001 Z06 has been grinding when going into 4th gear only when cold, so it looks like a rebuild will be in the near future. My question is who has torn into one of these 6 speeds to replace all the syncros?? Anyone know of an online disassembly guide?? Or did anyone find a 6 speed service mannual on ebay?? Ive done my share of 4l60e and am a licenced auto tech, so Im not to worried about ripping into it, but wanted to know other peoples experiance. Thanks Guys
Old 10-17-2005, 05:18 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
probably in service manual
Old 10-17-2005, 01:46 PM
MrPDJ
MrPDJ's Avatar
Try this thread over at LS2.com forums.
It's the best post w/pictures I've found for rebuilding the t-56. I ended up having mine rebuilt at MTI here in Houston.
Good luck with the re-build.
Old 10-17-2005, 02:10 PM
ericdwong
ericdwong's Avatar
Good link. Here is the service manual: http://www.ttcautomotive.com/English...ice_Manual.pdf
This service manual also covers the F bodys, Cobras and Vipers so some of the parts are a little different then the C5 (namely the "extension housing".. you'll see what I mean if you get that far).
I have replaced my 3rd gear synchro assembly (3rd and 4th gear synchros were one assembly if I remember right). It wasnt particularly hard, just time consuming. I got the replacements from Rockland Standard Gear (rsgear.com).
Your symptoms are exactly the same as mine- when cold it would grind. Bleeding the clutch and changing the trans fluid did not help. It progressively got worse.
Fortunately/unfortunately my slave cylinder died, so while the trans was out, I rebuilt it, on jackstands none-theless. If you need help, ask or PM/email me.
While you're at it, change the clutch/flywheel/hydraulics and add a DTE brace.
Old 10-17-2005, 05:55 PM
CrazyChris
CrazyChris's Avatar
Thanks for the links!
Old 10-17-2005, 08:19 PM
clone477
clone477's Avatar
Yeah thanks very much guys thats what I was looking for. Now is there a company that offers a complete rebuild kit??
Old 10-18-2005, 12:17 AM
Operations
Support Corvetteforum!
Operations's Avatar
Old 10-18-2005, 07:43 AM
clone477
clone477's Avatar
Whats the popcorn for?? Was I not supposed to ask were to find a complete rebuild kit??
Old 10-18-2005, 09:40 AM
ericdwong
ericdwong's Avatar
Not sure if theres a total rebuild "kit", but I got my rebuild components from Rockland Standard Gear www.rsgear.com . I only used standard parts, not performance parts. I dont plan on making my car run 10s. But so far so good, almost been 1 year, no leaks, grinds, funny feel etc on my daily driven car, almost 15K miles thats seen snow, towing a trailer and the drag strip.
Old 10-18-2005, 10:09 AM
Operations
Operations's Avatar
I want hear the answers you get because I want to know also. Possibly others have a diffrent idea as to the meaning of the popcorn pick, I see it as a method to watch a post I am intrested in. So I'm hanging around waiting to see what happens?
Old 10-18-2005, 07:22 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
Usually the popcorn means "this is gonna get good, I'm going to have some popcorn as this guy gets ripped on".
I may tear mine out this winter for a rebuild. Usually the only specialty tools you need for a tranny are good snap ring pliers, a dial indicator and a press. Hopefully thats all I need for this one.
Old 10-19-2005, 07:39 PM
DRR
DRR's Avatar
I found the T-56 manual at Tremic.com, complete with exploded views.
To 6 Speed transmission Rebuild
Quick Reply: 6 Speed transmission Rebuild
