Tire psi sensor with non EMT tires
Old 10-02-2005, 01:50 PM
CHRIS COVE
CHRIS COVE's Avatar
Default Tire psi sensor with non EMT tires
I currently have OEM EMT tires and need new rear tires now. I am thinking about going toward Michelin Pilot Sport PS2's. If I change to a none EMT tire how does this effect the tire psi sensors? Do the sensors still work or are they out of the equation and I need to reset my display everytime I start my car.
Any advise is appreciated. Thanks
Old 10-02-2005, 02:09 PM
Y2Kvert4me
Y2Kvert4me's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Sensors work just fine with non-runflats.
Get the PS2's, and enjoy!
Old 10-02-2005, 02:15 PM
stanger383
stanger383's Avatar
St. Jude Donor '09
Old 10-02-2005, 10:25 PM
CHRIS COVE
CHRIS COVE's Avatar
Thanks for the replies!!!!
Does fix a flat somehow effect the sensors?
Old 10-03-2005, 12:00 AM
wamara
wamara's Avatar
Cruise-In II Veteran
Most all "fix a flat" goop will ruin the sensor; use it only in emergency/as an absolute last resort. Better to carry a plug kit if you're running non EMTs.
Old 10-03-2005, 10:37 AM
Bills03Coupe
Bills03Coupe's Avatar
Go to www.tirerack.com and check out the Conti comfort Kit. It's a compressor with a latex sealant that does not harm the sensors!
Old 10-03-2005, 06:53 PM
pittguy79
pittguy79's Avatar
Has anyone tried the latex sealant referenced above. Did the TPS' still work after use?
Old 10-03-2005, 10:03 PM
W.A.M.
W.A.M.'s Avatar
I recently went with non-runflats and I bought the Tire Rack comfort kit.
It appears to be good quality and very compact. Its not suppose to mess up the TPS but I don't know that for a fact but maybe I will never need to know. You can use the compressor without the sealer if you choose.
I carry a plug kit also which I would use first if that would fail I would use the comfort kit sealer.
At the very worst I will be able to get the car home and replace or rebuild the TPS when I get time.
Glad I went with the non-runflats.
To Tire psi sensor with non EMT tires
Quick Reply: Tire psi sensor with non EMT tires
