Traction Control Problem---Code C1214
I'm having this random problem with the Traction Control and ABS service lights coming on.
DIC Code is C1214, which says Sol Valve Relay Contact or Coil CKT Open. Anyone know what this means or how to fix?
If I shut the car down after the service lites appear and then re-start, the Service Traction Control and ABS lites go away. Tks
Doug B
Doug B
code C1214
CalHusker...once you get any more info from the dealer...please post a response here. My problem is still intermittant. I do know that this code is related to the EBCM (electronic brake control module) which controls brake solenoids by grounding them. Then the BPMV (brake pressure modulator valve) goes to work to acutally open/close the solenoid. based on what the EBCM tells it to do...I think???
Regards
Doug B
Regards
Doug B
Doug B
Doug B
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Mine just started going from intermittent to every time within the past 2 weeks. Bill Curlee has this post about a possible ground corrosion issue http://forums.corvetteforum.com/show...214&forum_id=1
This is going to be a real PITA for me to get to because of the supercharger, and all the hoses going to/from the intercooler.
