Help increased Blow By after ported head install
Hi guys ,
Have ls6 with cam been running for years this spring decided to get a set of nice CNC ported heads with 11.4 CR had tune done gained 45 RWH .
These motors always have lot of Blow by but know with head swap noticing mush more BB than before puddle of oil behind TB .
Been running catch can for years decided to try plugging high pressure port behind TB where catch can would go and vent out to atmosphere to see if stopped oil behind TB . Did one HPDE event and still large puddle behind TB and catch can empty.
Come to find the oil is coming back through the fresh air feed line on low pressure side of TB to valve cover ! Not sure why or how to stop it .
Also I did install the updated valley cover with internal baffle few years ago and was under the impression that the updated VC had an PCV built in ? but just found out thats not the case . So have been running w/o PCV valve . The big Q is would not running PCV valve cause oil to feed back through the fresh air line to TB ?
Sorry for long winded post but really thinking of pulling new heads and going back to stockers .
Did you go with a different oil pump when you did the cam? Are you finding the puddles only after high RPM running or normal driving?
I have been running the updated valley cover for years and not had any issues with oil. Do you know the part number of the cover you used? There were two that were produced as I recall and I thought one required an external PCV valve and the other didn't. The later cover with the PCV restriction is 12577927.
Yes when did cam installed ported oil pump . Mostly oil after a track day and high rpm WOT throttle .
Has always been issue with oil in intake but heads seem to have made problem excessive.
Sure the increased cylinder volume and pressure there is more crankcase pressure ?
I did pull valley cover and take off baffle , there is no PCV valve in there ..
It is not a PCV in the normal sense, rather there are small restrictor holes on the bottom. Did you take a photo of the valley cover you installed or have paperwork from the purchase? The part number is key on whether you need an external PCV.
If you removed the baffle, what did you leave on the bottom of the valley cover? That may be why you are picking up excessive oil.
just removed baffle today to see what was under there . did not run car without it .
Yes it has t small restrictor holes on the bottom.
Will try to find PN ..
thx
thx
its still off can look .
Just think the new style with baffling and restrictor holes would cause more crankcase pressure and not release it ?
Pushrods & Oil Flow to the Heads
Thnaks ,
Actually just spoke to very helpful person @ Manton and he thinks by installing a oil restrictive push rods @40% will greatly help by limiting the amount of oil to top of head .
And this more so happens with after market rockers like the YT I have .
cheap fix @$175.00 .
Will see how it goes .
Thnaks ,
Air side from the valve cover to intake. At full throttle oil is getting forced
Through there & into intake. If that doesn't work, drink heavilly.
I have the restrictive pushrods. Waste of money.
I finally dry sumped. End of problems.
Just be careful as some of the guys in the other thread were starving the motor for oil since it was all out of the sump and up top in the motor. There were several ideas in that thread about how to resolve, with the ultimate being dry sump.
Dry sump = super nice but Dry sump = big $$$
