Help finding source of oil leak -->
I have a bone stock '04 coupe with 6300 miles on it.
Last time I changed the oil at 3300 miles, I noticed there was a thin dusting of oil on the bottom of the pan. I thought maybe I hadn't tightened the filter enough. So I cleaned it off and moved on.
Today I changed the oil again (6300 miles). This time, there was oil on the pan again. There was also oil around the filter (and whatever sensor that is by the filter), around a sensor on the opposite side of the pan from the filter (oil temp or level sensor?), oil on the exhaust by the pre-cats, oil around the drain plug, and a little up under the main pulley.
I cleaned it all off with brake cleaner and I'm going to check to see what gets dirty first, but I'm not sure if it will be easy since wind may blow it around.
Is there a common place that leaks on LS1s? Thanks for any help.
My pan is always clean (01 with 30K) but maybe some others guys can chime in and let us know what they think. Two question I have: Do you seen any puddles of oil under your car? Is it blowing under the whole underside? If it real minor and just moist around the filter area then maybe (MAYBE?) its not a big deal. Keep track of your oil level and keep us posted.
There's never any puddling under the car, and the oil residue is confined to the areas I listed in the first post -- basically no further back than the cats. Whatever gets back as far as the cats gets onto the cats and burns off there. I've been noticing an oil burning smell lately, so that explains it.
Anyone have any ideas where it might be coming from (based on common LS1 trouble spots)?
Originally Posted by FFR-Z06
Did you change the O-Ring on the drain plug?
Mine leaked also until I realized there was an O-ring.
Update
Update: I drove the car after cleaning the oil off and put it back on ramps to have a look underneath. Fresh oil showed up on the rear passenger side of the oil pan near the bellhousing. Are there two oil pans on the C5 LS1? Upper and lower or something? It looks like the leak may be coming from just above the lower pan. Then there is also the rear main seal possiblity... Is there a way to rule one of the two (pan or rear main) out?
BTW, to rule out the rear main, you might try removing the lower flywheel inspection cover and looking up at the back of the block.
Originally Posted by LoneStarFRC
The oil pan is one piece. One thing worth looking at is the oil pressure sender. It's behind the manifold (which btw, has to come off to change sender) and just a little towards the driver's side. You may have to use an inspection mirror and a good strong flashlight to see it. Removing the driver's side fuel rail cover helps.
If you have a "thin dusting" of oil I wouldn't worry about it it could be a porosity problem but if you have a thin dusting leading to drops on the floor then I'd be more worried about finding the source.
On early 97's the oil pan was a 1 piece but since then it is a 2 piece. I haven't heard of them leaking unless you've removed it. I had removed mine lower half 4 times reusing the original gasket with no leaks.
Any oil leak on a new car is unacceptable to me. I agree it's probably not a major problem but still annoying. Thanks for the info on the pan.
I'm looking into the oil pressure sending unit possibility now. Does anyone have a service manual drawing scanned or a pic they could post of its location?
Which manifold are you referring to? intake, exhaust, other? Can you post a pic or service manual drawing of the location? Thanks.
My 99 needed a new rear main seal.
The tech said this was very rare in C5's because they are usually pretty tight but mine leaked almost from day one, very slightly, until I had it fixed just as it was about to run out of the 3 year warranty
Obviously I don't mind a little oil in my garage, maybe I had to add half a quart between oil changes
Oil level sender
Oil temperature sender
