help need form A4 trans builder
need instructions on how to install valve opposite boost valve it is the only other valve held in by a snap ring that is visible from bottom of trans not in valve body? removed it by mistake thinking it was the boost valve and don't know which spring goes where. there are two different springs, valve, washer, and snap ring. i know that the washer and snap clip are last but don't know where the rest goes.
thanks,
99SilverC5A4
thanks,
99SilverC5A4
