stupid question but....
The drain hole is in the very back of the transmission. The Fill hole is on the driver side. Make sure you can get the file hole bolt loose before you get the drain. And you will need some type of pump to get the fluid in the transmission. I got mine at Sears. Coast about 10 bucks.
Good luck
Good luck
