RPM Signal Wire
RPM Signal Wire
I will be installing a LM-1 wideband this weekend and I need a rpm signal to connect the RPM converter to. Snyone know of a source source?
Keith
Keith
Keith
Keith
http://forums.corvetteforum.com/show...um_id=1&arch=1
http://forums.corvetteforum.com/show...ire&forum_id=1
http://www.zee-oh-six.com/install_pa...ht_install.htm
This is how to find a tach signal wire from under the PCM. You have to remove the passenger plastic wheel shroud (no big deal 10 minutes). I did not take these photos, but I cannot remember who did. This is the method I used to get tach signal for my DynoJet WBC....
Good Luck...
Good Luck...
