Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-01-2005, 07:26 PM   #1
slowjunk
CF Member
Default 2001 LS6 Head
How do you tell a 2001 Ls6 head from a 2002-2004 Ls6 Head. They are both 241 casting numbers right?
slowjunk is offline   Reply With Quote
Old 08-01-2005, 07:38 PM   #2
SFVetteman
CF Senior Member
SFVetteman's Avatar
The heads are the same but the valves and valve springs are different. the '01 uses LS1 valves whereas the newer heads use slightly longer and lighter titanium valves. The springs are identified by the color. I believe the '01 springs are yellow and the newer ones blue but I could have that wrong.
SFVetteman is offline   Reply With Quote
Old 08-01-2005, 08:51 PM   #3
Kexec
CF Senior Member
Kexec's Avatar
Default Heads
Also the Z06 casting is 243 not 241(LS1 head)
Kexec is offline   Reply With Quote
Old 08-01-2005, 09:20 PM   #4
Tino
CF Senior Member
Tino's Avatar
I believe the valves in the 02-04 are light weight sodium filled. These are not titanium valves, the new Z06's will have titanium
Tino is offline   Reply With Quote
Old 08-02-2005, 07:50 PM   #5
slowjunk
CF Member
Default 2001 to 2002 head visual difference
Visually other than the spring color, which I've heard is really not consistent in color or application, how do you tell them apart. Are there casting bumps, printed on parts numbers, etc. I'm looking at buying a pair and don't want to end up getting 2001 heads.
Old 08-03-2005, 02:13 AM   #6
jjjflex
CF Senior Member
jjjflex's Avatar
jjjflex is offline   Reply With Quote
Old 08-03-2005, 04:52 AM   #7
vettenuts
CF Senior Member
vettenuts's Avatar
Send a message via AIM to vettenuts
The original springs have a paint dot color code on them, unfortunately I don't remember the colors well enough to advise you. Do a search over on LS1Tech.com as well, this information is likely found there. This is of course assuming that the original springs are still on the head. Not sure what the visual differences are in the valves, but a quick e-mail to Bob at Precision Porting will likely provide some information on the valves as well. Good luck
vettenuts is offline   Reply With Quote
Old 08-03-2005, 07:47 AM   #8
see5
CF Senior Member
see5's Avatar
Quote:
The LS6 heads are #243 and I believe the 01 springs are blue with non sodium valves while 02-04 valves are sodium and springs are yellow. 05 LS2 is a 243 head with non sodium valves.
__________________
2000, 6M, Kinesis rims, VBP springs, Bilsteins, Poly bushings, CCWs -315/335 Hoosiers, (SM2), Cross-bar, G-Force harness, Sparco EVO 2 seat, forged, stroked LS7 (441CI), Halltech, Blackwing, Shaner TB, PowrMAF 100, LS3 intake, ported LS3 heads, not too much cam, Fast 50# injectors, C6 oil pan, Accusump, RPS Twin CF clutch, Kooks 1 7/8" headers, 3" catless midpipes, Z06 TIs, hardened 3.90 rear, EFILive V2, LM-2 wb, always tuning.
see5 is offline   Reply With Quote
Reload this Page 2001 LS6 Head
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 75 05-10-2013 05:09 PM
205 AFR Engine Dyno: A more complete picture Pitch Black Z Performance Results 29 07-04-2004 07:15 PM
is $850 a good price for a set of used LS6 heads + all the hardware? rwj383 C5 Tech 12 04-08-2002 08:11 AM
Stock torque specs, head and cam specs... ScreaminDemon C5 Tech 13 02-03-2002 01:53 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
