How do I fix rain leak from the roof?
Old 07-17-2005, 11:58 PM
aggie03
aggie03's Avatar
Default How do I fix rain leak from the roof?
Where the targa top meets the glass, there is a lot of water falling into the cabin. Washing the car is getting to be a nightmare and more importantly the heavy rain we've been having in Dallas lately is also getting in the cabin. How do I fix this. I took it to the GM dealership and they offered to adjust the weather stripping for $150 for both doors but said they couldn't gaurantee it would be leak proof. Any suggestions, and if anyone's in the Dallas area, do you know of any good shops??
dalewmccarthy@gmail. (03-27-2022)
Old 07-18-2005, 05:10 AM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
ok,......are you talking on the sides or the front?? and can you post pics of the areas we are looking at so people can offer suggestions.
and damn that has got to suck
Old 07-18-2005, 06:02 AM
nightmel
nightmel's Avatar
I have the same problem, it is annoying drops that com from where the front of the Targa meets the windows. Drivers side especially. If you look at that spot you may see that that is the place where the weather stripping doesn't overlap the glass as in other places. It causes a lot of outside wind noise at greater speeds also. I have not tried it yet but It was recommended to me to us silicone inside the weather stripping to push it out a little bit. I plan on replacing with new.
Old 07-18-2005, 06:47 PM
aggie03
aggie03's Avatar
Here are some pictures of wear the leaks start from then turn into a full fledged water fall.....
Old 07-18-2005, 07:32 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Try Black RTV sealant; cna be purchased at any auto parts store. apply it onthe area where you think is leaking then install the top and let it dry for 24 hours before gettng it wet.
Old 07-18-2005, 07:33 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
Try Black RTV sealant; can be purchased at any auto parts store. apply it onthe area where the top meets the windshield. then install the top and let it dry for 24 hours before gettng it wet.
This stuff works like a charm for t-tops and targa tops.
Old 07-18-2005, 07:42 PM
aggie03
aggie03's Avatar
Is Black RTV a type of caulk?
Old 07-18-2005, 11:35 PM
kg54trains
kg54trains's Avatar
Default Window Leaks...
This is a problem that some of us will experience, I am one also. There are adjustments in the door that control the windows and the angle that is completed to the weatherstripe. A thread with pictures of the doors access points(2) can be checked. I also believe there is a GM service bulletin about the window leaks that are coming from the clip on the weatherstripe
Old 07-19-2005, 08:26 PM
aggie03
aggie03's Avatar
thanks guys. I've got an appointment at the stealership tomorrow, let's see what their verdict is.
Old 07-20-2005, 05:11 PM
aggie03
aggie03's Avatar
The stealership said my weatherstripping is fine and they offered to pull out all the weatherstripping and reinstall it for $480!! Keep in mind this price still doesn't gaurantee I can even go through a car wash, but they said will gaurantee rain will not get in. Any other suggestions on what I should do........? To me, it's not a big deal and I can drive another car if it's going to rain hard, but it seems like $480 is a rip off for no new parts and just reinstalling my old weatherstrip.
Old 07-20-2005, 09:00 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
Its a black paste that blends into the weather stripping when it dries.
Ive used it on my old mustangs with T-roofs and it always sealed the leaks.
Old 07-20-2005, 09:09 PM
Monster231
Monster231's Avatar
You just have to adjust the top. Its not actually leaking from there, it leaks from where the top meets the winsheild and carries back and drops in from the mid window area. Adjust the top sit forward more and it will tighten the seal, and you should be ok from there
Old 07-21-2005, 04:29 PM
Fasthotrod
Fasthotrod's Avatar
You might find this interesting...
http://www.corvetteactioncenter.com/....php?qstId=203
It deals with a leak above the glass, by the blowout clip. Hope this helps.
Mark
Old 07-21-2005, 10:24 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
All you need to do is adjust the windows!! There are adjustments that allow you to have the glass move up and also move inward. All you need to do is tilt the window glass inward to apply a little more pressure on the gasket.
Save your money and adjust the glass yourself> If you cant do it yourself, find a shop that knows their *** from a hole in the ground and get them to adjust the window.
That dealership sounds like a bunch of winners! Pull out the gasket and reinstall it! Geish!!!!!!!! I would fix it for you for FREE if you lived close!!! If you felt generous you could donate the $450 to my C6 ZO6 fund!!!
Bill C
Old 07-22-2005, 03:54 AM
2fast4sanity
2fast4sanity's Avatar
Go to http://www.johndennington.com and go to the how to section of his site. Look for the window tip in adjustment. This should solve your problem.
Old 07-22-2005, 10:05 AM
John Cullen
John Cullen's Avatar
Default window leak
2fast4sanity,
Thanks for the link,great stuff.
John
To How do I fix rain leak from the roof?
Quick Reply: How do I fix rain leak from the roof?
