Check Engine Light - UGH
Ok -
Driving around today at Bloomington Gold - Check Engine Light comes on.
Car is running fine, Oil Pressure is a bit low - 22-26 PSI.
Trans Fluid / Engine Temp all in the 220's.
It was very warm out today 95+.
Is it a stupid $ 1.00 Sensor - or should I be worried and leave thing in the Garage this weekend.
HELP -
DOC
HELP -
DOC
well,well...
just as i was thinking of posting about MY CHECK ENGINE LIGHT...here you are!mine just came on too,while sitting at a light.i tried the old turn car off/on routine,that didn't work!i'm going to follow the advice i give my customers at the dealership i work at,if it's not flashing,don't worry about it,it's probably some emissions thing...we'll see what happens!
Codes --
10-PCM -
P0113 - Air Intake Sensor Low V
P1111 - Air Circuit Intermit. High V
Think these are all History though - They had the H C after them.
DOC
DOC
10-PCM -
DOC
DOC
Turn on car - but don't start it.
Hold Options button down and push Fuel Four Times -
The DIC starts to roll through all the codes.
Write them down quick or wait and then you can toggle through and get them.
Go to Yahoo - Search DIC Corvette- It's the first link.
This tells you what's wrong with the car.
DOC
DOC
http://www.stengel.net/diccodes.htm Here is the site.The c means current regardless of the h.If it only has an h then it is history.You can get rid of the check engine light if you clear the codes.It sounds like you need amn intake air temp sensor.
AMN intake sensor
Do you mean new Air Intake Sensor??
What is AMN??
Clarify.
If so - Is it driveable - I noticed it would rev up at light then die down when I was sitting there tonight.
Mark
What is AMN??
Clarify.
Mark
Originally Posted by drdoc22
Did not know that - I though H was history.
H C -
What does that stand for?
Doc
H C -
Doc
After all of the codes has been shown the DIC will display "manual diagnostics, once here you can hit (I believe the options button) to scroll forward and the button above that to scroll back thru each module, when you get to PCM it will display something like "PCM 2 codes" with this shown press and hold the reset button to erase the codes Once erased run the car for a while to see if they stay or come back, I have an O2 sensor code that pops up once in a blue moon and it shows as a current fault but I can erase it and it will stay away for a couple months.
Yes i mean iat sensor.You could do a few things.I will test the impeadance of mine at ambiant temp and give you that info so you can find a resistor that matches and replace the sensor until you can get a new one.Or you can drive it like it is and probably be fine.
Sensor
But - why would the check engine light pop up now. That code was out there this past Winter.
Like I said, it would rev up at the light (2K) then back down to idle.
Weird -
I don't know - I just don't want to blow something up thats going to cost two arms and two legs to fix.
doc
Weird -
doc
Originally Posted by jessem
here goes!A1 rdcm-3 codes,ao ldcm 1 code,60 ipc 1 code 28 tcs 1 code,10 pcm 1 code,28tcs c 1225 h.what the hell is all this????
Got to get the exact codes.
They are by letter -
Like B2282 or
P 0113
Write those down. Note if the have an H or C after them as well.
Go get them again.
DOC
Thats odd mine revs up at a stop somtimes until i take my foot off the brake.Sounds about the same.I have ghost codes all the time that do not throw codes until once in a blue moon.Then i get an o2 sensor code ive never had.Turns out i have o2 sims on my ride and there throwing codes for some reason.
codes
p0430hc,2285h,B2283H,c1225H,u1064H,u1160 h,u1160h.that's it,although there was a0-3 codes,couldn't get them.But i did push reset,and cleared them all and now my ck.engine light is out!
