Lowering C5 on stock bolts
Old 06-19-2005, 04:56 PM
BickyDhadwal
BickyDhadwal's Avatar
Default Lowering C5 on stock bolts
If anyone has lowered there c5 using stock bolts could they please post pictures and could they please provide me details on how to do it...i know its been posted before but i can't seem to find it....without cutting the bushings etc...just on stock bolts....if anyone can provide details on how it could be done or give me a link to a discription it'd be greatly appreciated...
BickyDhadwal is offline
Old 06-19-2005, 06:03 PM
VetteSiNz
VetteSiNz's Avatar
http://www.frankhunt.com/FRANK/hobbi...5_Lowering.htm
VetteSiNz is offline
Old 06-19-2005, 06:06 PM
Icemanskis
Icemanskis's Avatar
Cruise-In VI Veteran
St. Jude Donor '05
Here you go: I have a few pics of lowering on stock bolts.
The rear end is easy. No need to jack the rear end or take the rear wheels off, but it may be easier for you to get under the car if the back is brought into the air. Here is a pic of the passenger rear. The bolt is in the middle of the picture. The nut is on top of the leaf spring and the hex head is below the leaf spring. I think the bolt is 18mm, but I dont really remember. Take a socket wrench to the hex head below the leaf spring. At the same time use an adjustable wrench to hold the nut atop the leaf spring in place so it doesnt move when you turn the bolt. Loosen the bolt counterclockwise until there are about two thread showing above the nut. Do the same for the other side.
Here is a pic of the driver side rear bolt.
Ok, now for the fronts. Jack up the front end and place it on jack stands. Take the front wheels off. In order to lower the fronts, all weight must be taken off of the front spring. You can use your floor jack and a small piece of wood as shown in the picture below. As the picture shows, it is important to get as close to the end of the leaf spring as possible to take all of the weight off. Leave the jack in place.
Next, now that the front is on jack stands and the weight of the car has been taken off of the spring, get yourself a 10mm socket (again I forget the exact size) and an adjustable wrench. The bolt is a little hard to see in the next pic, but i circled it in white. However, the front bolts are reverse threaded, so you want to turn them counterclockwise. This means, that when you are done, there will be more threads showing above the nut.
The lowering was done at forum members' "connecticut" and "nomadman2001"'s garage. thanks guys
Icemanskis is offline
Old 06-20-2005, 12:09 AM
BickyDhadwal
any pictures of the car after its lowered...i want to see how low it sits...after i got it up on the the lift at work...i got kinda scaried and never bothered doing the work...first off it was really confusing without the pictures...now it seems really clear and secondly ive done quite a bit of damage without even knowing...ive bottomed out A LOT
the roads around my house aren't exactly the flatest i guess i have to go on more of a angle....on the passenger side bottom panel OUCH!!! scaried me off never ended up doing it...but i would still like to see how low it sits after lowered...how many inches do you drop approx...front and rear?? still thinking about it not sure if i should take the risk and drop it thanks again
Old 06-20-2005, 12:15 AM
GMvert
Support Corvetteforum!
GMvert's Avatar
See my pics. Lowered on stock bolts as far as possible.
GMvert is offline
Old 06-20-2005, 12:16 AM
RainJ
RainJ's Avatar
Location: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
stock bolts here too - but added larger tires and wheels too!
Rain
RainJ is offline
Old 06-20-2005, 12:18 AM
RainJ
RainJ's Avatar
http://www.rainontheinternet.com/200...e/site1020.JPG
RainJ is offline
BickyDhadwal
Icemanskis - thanks for the great detailed explanations and pictures...i might end up lowering it tomorrow
especially after seeing RAIN's pictures very nice
Old 06-20-2005, 12:13 PM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
ice, nice job on the "how to" and thanks for the credits. the car will be slammed today w/ cut bushings, it's gonna look SICK!!
SteveDoten is offline
Old 06-20-2005, 01:47 PM
Icemanskis
Icemanskis's Avatar
St. Jude Donor '05
Here are the before and after shots: The car was lowered about 3/4'' all the way around. But, I have the Z51 suspension, which I have been told will not lower as much as the standard suspension. You should be able to drop an inch or a little more on stock bolts with the standard suspension. I was not satisfied with lowering only on stock bolts. Hence, today the front bushings will be cut and longer rear bolts installed. I will post the pics tonight.
Before lowering pic:
After lowering pic:
Old 06-20-2005, 04:12 PM
BickyDhadwal
i have the upgraded suspension as well :o ..its is a big improvement considering i don't want to be too low becuase i bottom out a lot already...thanks for sharing great pictures
If you cut the bushings does that not make the ride a lot stiffer and not as smooth??
Old 06-20-2005, 10:03 PM
dads01dream
dads01dream's Avatar
So with lowering only 1/2" all the way around, you *must* get the alignment re-done? If yes, do you simply have the shop set it back to stock settings?
TIA
dads01dream is offline
Old 06-20-2005, 10:10 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
pic..
Ikester is offline
Old 06-20-2005, 10:33 PM
Icemanskis
Icemanskis's Avatar
St. Jude Donor '05
TIA
Cut the front and rear bushings today. My car is seriously slammed how. About 26.5 inches from pavement to top of wheel well. Pics will be up soon. I didnt really notice a significant change in the ride quality. It is stiff but not too stiff for me, even with stock z51 shocks.
Old 06-20-2005, 11:21 PM
Icemanskis
Icemanskis's Avatar
St. Jude Donor '05
http://forums.corvetteforum.com/show...1&forum_id=103
Old 06-21-2005, 01:10 PM
BickyDhadwal
looks SWEEET!!!!!!!!! (im lowering mine on saturday...stock bolts) thanks again for the great pictures
Old 06-21-2005, 01:11 PM
BickyDhadwal
O YEA ANOTHER QUICK QUESTION...for anyone thats lowered it on stock bolts...did they also have to re-align??? (i got my alignment done just a month ago )
To Lowering C5 on stock bolts
Old 06-21-2005, 02:21 PM
jrc27
jrc27's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
yup
jrc27 is offline
Old 06-21-2005, 08:08 PM
Ikester
Ikester's Avatar
CI 6-7-8-9 Veteran
Not me, car has been lowered for 1 year now and my tires still wear evenly.
Ikester is offline
Old 06-22-2005, 12:56 AM
SilverBulletZ06
SilverBulletZ06's Avatar
Thanks all in this thread. Just lowered mine. Man, what a difference 0.5" makes.
SilverBulletZ06 is offline
Quick Reply: Lowering C5 on stock bolts
