Column Lock just happened to me
OK, I read the sticky at the top of the page. However, I still have questions.
First, since I have a 1999 MN6, and according to the sticky, all they do is reprogram it to cut off the fuel above 2mph, how does that fix my column lock problem?
Second, since it is out of warranty, are they going to charge me for fixing it, even though it is a recall?
Third, what will the fix be to make the car go again (maybe this is #1 re-asked again, I still don't understand the FIX part of the recall equation?)
1 Post
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
The system must be unlocked when you start the CLB install though. And all recall work would be done at no charge, unless they found something in there that was broken.
I think they have to honor the recall even if it is out of warranty since it is a safety issue.
To fix it, install an aftermarket CLB, OR buy the GM Harness K kit for the automatics and install that yourself. The GM kit requires that you remove the lockplate to complete the installation, but it has the advantage of keeping the actuator in the circuit to maintain the correct resistance in the BCM circuits. The CLB takes the actuator out of the circuit completely and there is a possibility it could eventually damage the BCM. Good luck....
Clb
I took my 1999 FRC to the dealer for the blown oil pressure sensor, the dealer ran my vin then called to inform me of the recall on the column lock. They were going to fix it for free, charge GM probably.
I declined the repair as I read the horror stories of the gremlins created after the recall repair.
I had the CLB anyways, bottom line buy the CLB. I bought mine from Thunderracing.com, installed it myself. no further issues.
Good luck
Jeff
Save Da Wave
Good luck
Jeff
Save Da Wave
