Best Fan Belts ?
Old 04-09-2005, 12:40 AM
CHARARNIE
Cruising
CHARARNIE's Avatar
Default Best Fan Belts ?
I Am Going To Change My Fan Belts On My 2000 C5. I Would Like To Put The Best Belts On So They Last A Long Time.
Old 04-09-2005, 12:49 AM
kingrobby25
kingrobby25's Avatar
I use the goodyear gatorback belts and they seem to work well(no squeaking) and the don't cost an arm and a leg.
Old 04-09-2005, 12:55 AM
MAC5
MAC5's Avatar
Just installed the Gatorbacks a month ago.
Old 04-09-2005, 01:46 AM
wantmyc5
wantmyc5's Avatar
I've done the same, and got them with a coupon 50% off!
Old 04-09-2005, 07:39 PM
CHARARNIE
Cruising
CHARARNIE's Avatar
Default fan belts
thanks a lot gatorbacks it is.
Old 04-09-2005, 07:59 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
What are the part numbers for the Gatorback fan belts for those of us using ASP Underdrive Pulleys?
Old 04-09-2005, 10:40 PM
Jserman
Jserman's Avatar
were can you buy these at???
Old 04-09-2005, 11:15 PM
MAC5
MAC5's Avatar
Order mine through Autozone. They occasionally run a sale.
Here are the Goodyear part numbers for a 1998:
Poly-V Belts
4040420 Poly-V, w/AC
4060802 Poly-V, Alt & PS
Old 04-10-2005, 11:53 AM
Z06ufgrad2002
Z06ufgrad2002's Avatar
I also use a 10mm shorter than stock belt and has been working beautifully for over a year.
Old 04-10-2005, 04:15 PM
1NYCGUY
1NYCGUY's Avatar
Here are the Goodyear part numbers:
Poly-V Belts
Autzone is the easiest way to get them quickly....
Old 04-10-2005, 07:19 PM
birch64
birch64's Avatar
goodyear gator backs. got mine from: http://www.pickproparts.com/ best price 4040420 $11.51 and 4060798 $17.75
Old 04-10-2005, 07:26 PM
birch64
birch64's Avatar
Poly-V Belts
for a 2000 part numbers are: a/c 4040420, alt & ps. 4060798 is what goodyear and pickproparts.com are showing. Replacement Products for CHEVROLET CORVETTE - 2000 5.7L V 8 Eng
Part No. Applications Usage Metric Part No. Replace By
Poly-V Belts
4060798 Poly-V, Alt & PS
Tensioners
49283 Accu-Drive Tensioner, PS & Alt Drive
49297 Accu-Drive Tensioner, AC Drive
Idler/Tens Pulley
49006 Idler Pulley
49021 Tensioner Pulley, PS & Alt Drive
Old 04-10-2005, 09:03 PM
MAC5
MAC5's Avatar
Interesting that they changed the belt size on Alt, power steering belt for only two years according to the Goodyear website. 1999-2000 use the 4060798 and all the other C5 years use the 4060802.
Tensioner and idler pulley numbers are all the same all model years. So they must have used a different size pulley on either the power steering pump or alternater those years. Very small difference since the belt length works out to only 4/10 of an inch (4060798 is smaller).
Geez, I have too much time on my hands tonite, I'm outta here !!
Old 04-11-2005, 02:16 AM
flash134
flash134's Avatar
St. Jude Donor '05
Just put both on; No problems
To Best Fan Belts ?
Quick Reply: Best Fan Belts ?
