Column Lock Simulator
Old 04-21-2005, 09:43 PM
tah81
tah81's Avatar
Default Column Lock Simulator
Gang, I just received my CLS from Thunder Racing and all that was in the box was the small CLS module...no cigarette lighter adapter as shown in the LS1howto article. Is that needed for all installations? Mine is a 99 6-speed. Thanks. Tom.
Old 04-21-2005, 09:46 PM
tdahl
tdahl's Avatar
yup its easy, just follow the instructions on the bag... fuse 25 I think..... easy and works just fine!
Old 04-21-2005, 11:36 PM
tah81
tah81's Avatar
So is the cigarette adapter required for installation???
Old 04-22-2005, 02:19 AM
Cscokd
Cscokd's Avatar
Gosh I thought the CLB came with the cigarette lighter adaptor. It's used to unlock your ECL motor before installation of the CLB. Follow the instructions carefully that came with your unit.
If no instructions, then the way I would do it is to insert the key and turn to on, but don't start the engine. Observe that the steering is unlocked. While in this state, disconnect your ECL harness. Turn off ignition and remove key. Install your CLB and plug into the harness. Then try it. If you get any error messages, reset your BCM following instructions in my sticky. This should accomplish the same thing without the cigarette lighter adaptor. Good luck.
John
Old 04-22-2005, 07:19 AM
Ragtop_Rob
Ragtop_Rob's Avatar
St. Jude Donor '17
It depends on the kit you buy - one kit has it the other does not - BOTH work fine. The one without the lighter adpater, you just pull a certian fuse to actuate the lock. If there are no directions, get them emailed or faxed to you - it is EASY.
To Column Lock Simulator
Quick Reply: Column Lock Simulator
