service colum lock msg on A4
my c5 is a stock A4 with 60,000 miles and today when i got in it to leave i put it in reverse and backed up some and pushed the brake the car shout off and the display said to remove key and wait 10 seconds, so i did and now the display said service colum lock. but the wheel is not locked into place and the car sounds fine but move it eather in drive or reverse and press on the brakes and car dies, also the ac controle lights will not come on the ac still workes but no light with head lights. are these related? need much help thhanks.
make sure that your recall has been performed PROPERLY or try one of the column lock removal procedures that some of the do-it-yourselfer guys do. It seems that almost everybody has problems removing the column lock sucessfuly. I'm just leaving mine up to chevy.
I have an a4 and when I got the same message, my column locked and could not be moved. I eventually got it unlocked and installed a column lock bypass from Thunder Racing. Since then, I've never had a problem. I've gotten several recall notices from Chevy, but I refuse to have them do the recall.
My car had the column lock recall done when I bought it. If yours has not had the recall done, that would be something to get done soon. If the recall has been done to your A4, the wheel will still turn when the car is off. The column simply doesn't lock anymore after the recall.
1 Post
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
