Optima batteries?
St. Jude Donor '06-'07
A lot of horror stories beginning to show up on Optima batteries. I'm on my 3rd Optima Red Top in 4 years---Cells keep on going dead. I'll be shopping for something different the next time I need a battery...Good luck w/ your search....
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by Wolfmanjohn
It's tough to go wrong with an Interstate.
Whatever the hell you buy....do yourself a favor and hold on to your invoice!! The Optima peeps have a really hard time trying to replace a batt without your invoice!! Myself....I have had now a total of three Optimas go bad in two years on three seperate cars!! I don't think they are what they use to be!! Dunno...maybe its just my luck.
Shahram
Shahram
Originally Posted by Autoworker
Getting ready to buy a battery for the '98. Any stories good or bad, on Optima batteries in a C5?
Sounds like you just need to get a name brand battery and convert to a top post battery to avoid leaks.
I have had good luck with Delco batteries if you get one that does not leak. Luckily, I have a 2004 Z06 and the factory went back to top post batteries so I have had no problems.
Shahram
Shahram
According to the owner of a local battery shop that sells different types of batteries, including Optima, he said they aren't what they used to be. He recommended I buy an Orbital...
My Interstate Died in 2 years as one cell was bad and it sucks having to monitor the fluid level which is not necessary in a sealed battery. I had a battery tender on it and it should have lasted longer. This brand is WRONG and I will never buy another one.
My first optima red top in 06 lasted a good 5 years, then went to yellow top and it went 7 years, after that replacement optimas must have been junk because they all went bad after about 1.5 years so I switched to Champion AGM a few years ago and still going strong.
A 17 year old thread.....................
