flickering lights on my 99
Old 02-28-2005, 05:53 PM
happa
happa's Avatar
Default flickering lights on my 99
I need some help, I have a 99 coupe and I have a flickering lights problem. When Im driving my headlights and my interior lights flicker?? Can someone help me out so I can fix this mild problem. Thank You
Old 02-28-2005, 08:00 PM
Rex99Coupe
Support Corvetteforum!
Rex99Coupe's Avatar
TTT
I have noticed this on my 99 Coupe also.
Old 02-28-2005, 08:18 PM
91VetteOkc
91VetteOkc's Avatar
Sounds like a bad ground. I just read on here over the weekend about grounds being a common issue due to the unseen corrosion in the connectors. May try moving the wires on the chassis ground connectors and see if you can identify it.
Old 02-28-2005, 08:24 PM
happa
happa's Avatar
thanks man, Ill try that. Would it be a bad battery? if its not the ground
Old 02-28-2005, 08:34 PM
speedfreek155
speedfreek155's Avatar
I've got a ton of 12Volt eperience(In another lifetime , managed a Circuit City roadshop , first class MECP cert ) and GM's are notorious for ground problems , I've encountered this on many vehicles and it always seems to be under the dash somewhere .
Old 02-28-2005, 09:34 PM
happa
happa's Avatar
thanks man ill try that too.
Old 02-28-2005, 09:43 PM
TOPGUN9
TOPGUN9's Avatar
I had a simliar problem with dimming headlights while operating the power windows on my '99 coupe. A couple weeks later, my battery took a dump on me. I would check the battery first. JMHO.
Old 03-04-2005, 12:12 PM
91VetteOkc
91VetteOkc's Avatar
If it is the battery it is likely a bad connection on the battery. Would not expect that the car would start if it was going to have a noticable affect on the lights. If it seems to do it on the bumps instead of smooth ground, then I still suspect bad connections somewhere.
Old 03-04-2005, 02:07 PM
Sportsdude
Sportsdude's Avatar
Replaced my battery and it resolved my problem.
Old 03-04-2005, 11:22 PM
Corvette Tommy
Corvette Tommy's Avatar
St. Jude Donor '08-'09
My head lights use to dim when i hit the brake.........battery checked out OK........but replaced it anyway and the problem stopped
Old 03-07-2005, 10:09 PM
2pedala
2pedala's Avatar
Default every shift
my 2003 would dim at the slighest pull of power even when auto shifted. these cars seem to be voltage hungry, battery fixed it at 7,500 miles. makes me wonder if after market high amp alternator. is not warrented
To flickering lights on my 99
Quick Reply: flickering lights on my 99
