Is it possible to turn off the tire pressure sensors?
http://www.stopforce.com/RPO.html
Scroll down to Setting up tire pressure monitoring; where it says "Toggle function on," toggle it off instead.
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
So, for 97-00 cars, there is no way to turn off the system.
Well...you are only partially incorrect. The original poster has a '98 and it is not possible to turn the Tire Pressure Monitoring system off in those early models. It can only be done on an '01 and newer model using the Tech II tool.
I was under the impression that 97-00 models could not be turned off.
Originally Posted by Cajun99
Hmmm, I knew you could use Tech2 to turn on the monitoring system on 2001 and newer Z06s but I didn't know that could be used to disable the monitor on pre-2001 Corvettes.
You may want to check this out. I copied it knowing I would need it sooner or later. It is not in the tech section that I could find. I don't know if it works, but it would be worth a look see.
Corvette Forum > C5 Tech/Performance > I found a way to disable 97-2000 low tire warning system,no messages (Printable Version)
Post Title: I found a way to disable 97-2000 low tire warning system,no messages
Posted by: C-5 TECH at 6:48 PM 11/23/2003
There have been many posts in the past inquiring on how to turn off the low tire monitoring system on the 1997-2000 C5 so that no messages will pop up on the DIC.I stumbled upon this,and it should work for those adding custom wheels with no sensors,or for those that prefer to eliminate the system all together rather than replace faulty low tire sensors...
1st,simply disconnect then reconnect the electrical connector to the low tire/door lock control module located over the left rear wheel well.When doing so,the module looses its logic and no longer looks for a signal from the low tire sensors.You will then have to reprogram your remotes,and of course,do not relearn the tire sensors
I will add this to the Tech Tips
Post Title: Re: I found a way to disable 97-2000 low tire warning system,no messages (C-5 TECH)
Posted by: vettemaster1 at 6:52 PM 11/23/2003
how far have you drive without setting code? if a long way excellent!!
Posted by: Monster231 at 10:32 PM 11/23/2003
WIll this work if you dont have sensors. I think after a while it will relearn
Posted by: hrdtopv8 at 10:41 PM 11/23/2003
That's great if it's a permanent fix!! However, is this module visible or easy to get to? What pieces of the interior do we have to remove to do this mod?
Like I said. I don't know if this works or not. I have not tried it. You may be able to get intouch with C-5 TECH to see if he has more information. If you decide to try it please let me know how it works out!
Turbo5
Turbo5
Received 3,112 Likes
St. Jude Donor '21-'22
If your REALLY want to turn them off, you can actually upgrade to the newer TPMS system. That way you have the option to just turn it off.
Even if you bought a base or z06 2000-2004 RFA module you still can't turn it off/or on with tech 2. Unless you did this first before moving to the 98.
Received 19,395 Likes
'20-'21-'22-'23-'24
Moving this to the Tech section.
I’ve recently brought my ‘99 back to life after it hadn’t been used for circa 9 years. I knew I was running without any TPMS sensors. To my amazement I had no warnings! BUT after some days of running and use “ping” the warning started. I think it’ll relearn.
Not sure if you got an answer to your question. My 2004 CE Vert tire pressure monitoring system quit working as well. I thought it had been turned off accidentally by the mechanic at the dealer somehow. After a lot of research I found that the key fob remote sensor in the fender well behind the driver's seat also is the receiving unit for the tire pressure monitoring system. The TPMS had quit working but the remote key lock still worked. I ordered a new sensor from a company in FL and it fixed the problem. I have my TPMS working again. The place I ordered it said the little flanges or fasteners are flimsy and break off. They sent me one in a box without padding and both flanges were broke off, so we used double-sided tape. It stayed put and works fine. I'm told that earlier C5s like yours use a different part number than mine, alrhough the parts are almost identical. Hope that helps.
Mark from Michigan
Mark from Michigan
This does work I have a 98 and was want to use the newer (cheaper) fobs and tpms sensors. But got a Zo6 RFA module and my tire sensors were all gone. No program no reading no nothing. So had to hunt down a base 200-2004 RFA box and got it all to work.
You're in the wrong forum.
