Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-14-2005, 04:19 PM   #1
pwrshhftd
CF Senior Member
Send a message via AIM to pwrshhftd
Default aluminum shift forks C5 .. help
Does anyone know for sure what vin's are affected... by the TSB.. that pertains to aluminum shift forks?
I had my old 2002 repaired for this problem and the steel forks installed.
Now my new late 2002, is supposedly not affected, buy this TSB.
Where can I find the exact cutoff for this problem.
I have T-minus zero days till my warranty is out.
pwrshhftd is offline   Reply With Quote
Old 02-14-2005, 04:38 PM   #2
tmickey
CF Senior Member
tmickey's Avatar
Is this recall issue or what?
I just bought a 02,Z
tmickey is offline   Reply With Quote
Old 02-14-2005, 05:39 PM   #3
pwrshhftd
CF Senior Member
TSB i think its like 3080.. but i cant find it anywhere
the dealer claims, my car isnt affected..
i think it is
help!
Old 02-14-2005, 07:42 PM   #4
pwrshhftd
CF Senior Member
Its TSB 3020
can anyone help me find more info on this?
Old 02-15-2005, 09:37 AM   #5
pwrshhftd
CF Senior Member
ttt
Old 02-15-2005, 12:03 PM   #6
early shark
CF Senior Member
How late is your 2002 model?
My vin is 33893.
early shark is online now   Reply With Quote
Old 02-15-2005, 12:35 PM   #7
pwrshhftd
CF Senior Member
production date feb 12th 2002
Old 02-15-2005, 06:44 PM   #8
RAFTRACER
CF Senior Member
RAFTRACER's Avatar
The information you are referring to was never a bulletin it was GM preliminary information, #pip3020. This information included ALL 97-03 Corvettes, 97-02 camaros and 97-02 pontiac firebird, with M12,MM6 or MN6. These parts were updated sometime during the '03 production, but I haven't yet researched exactly when. In addition to the aluminum shift fork being replaced they are also to replace the 3-4 synchronizer hub assy and both 3rd & 4th blocking rings.
This has been a problem on these cars for sometime, obviously. We have repaired may of these transmissions under warranty, but now GM seems reluctant to stand behind their product (or Tremec's). We are constantly under scrutiny by our district service manager on transmission repairs.(because this affects GM warranty cost greatly, partially because of much inflated parts prices).
Besides the fact that they think the shift fork is the culprit, the synchronizer hub keys are made of JUNK (stamped steel). Albeit expensive Rodney from RPM (crashed94) has available billet or tool steel keys which probably will never break and thats what I've been installing lately in our "REAL" cars. This is the component that causes the car not to shift properly between 3rd-4th.
RAFTRACER is offline   Reply With Quote
Old 02-15-2005, 10:38 PM   #9
pwrshhftd
CF Senior Member
i changed dealers... and they are goign to do the swap fo rme this coming monday..
I will post my results
thx for the info
Old 09-21-2010, 12:53 AM   #10
vettjeff
Junior Member
Default Steel shift forks, when?
Isn't there anyone that can get/give a definitive answer on when the trans upgrades ('02-'03) were made? I have tried everything to find this out, including going directly to GM, nobody has an answer. You know that the way computer records are kept now they should be able to just punch this in and get the answer----they ignor you! Anyone else had the same problem? This has been my only post because everything else has been always simply answered. I don't know how all this posting works but you can answer me at jeffgemutliche@shasta.com
P.S. my 1st vette was a'58----things were much simpler then---yeah--I'm an "old" guy.
Thanks, Jeff
vettjeff is offline   Reply With Quote
Reload this Page aluminum shift forks C5 .. help
Tags
2002, 3020, 34, aluminum, change, coorvettes, corvette, fork, forks, pip3020, shift, steel, synchronizer, transmission, tsb, vin, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
