3.42 gear help!!!!
3.42 gear help!!!!
I am having a problem with the car computer. When I changed to 3.42 gear in my 2003 automatic I keep getting the code 1870.
A guy used a H.P. programer to change the computer. It seems to work for about 75/100 miles then the code comes back.
I do have the LS1 program but have not used it yet, because I don't know how.
Can anyone help or tell me what to do ?
Location: Greenville, South Carolina Drive It Like You Stole It !!!
St. Jude Donor '05
I'm about to do the same Mod.....I would be interested to know the reason also.....Before I do it.....Thanks
Do you have Ls1 edit or Hp tuners? It's not the end just a minor set-up change. I didn't get the code because I went to a vacuum controled shift but still had to adjust for shifting.
P1870 means that the TCC slip error tables were not changed during the reprog and the PCM thinks there is a malfunction (excessive slippage) in the tranny or TC - when there really isn't any problem with the tranny/TC.
Before you double check the programming - are you certain the TC is locking - and actually not slipping excessively ?
I have the LS-1 Edit, I have not used it. The guy I went to had the H-P and had used it before so he used that one. He has moved out of town. How can I use the LS to make the right adjustments ?
I just got your e-mail dated 2/10, man thats slower than the postal service. If you still need help I sent you my phone number and I will pm it to you incase that takes 4 days also.
