Removing rear brake rotors? Bolts are STUCK!
Supporting Vendor
1 Post
Are there any special tricks to getting those two 21mm bolts off that hold the caliper bracket in place? I see from reading the service manual that they are supposed to be tightened to 125 ft/lb and that the bolts have a thread sealant on them when they are new. However, even my impact wrench is having trouble breaking them loose.
I have already applied a coat of WD40 to hopefully break up and rust bonding that's occurring, but other than keep trying with an impact wrench and WD40 do you guys have any tips on how to get these off?
Premium Supporting Vendor
P.S. Give it the idiot check. Generally, unless you have a lift, you are looking at those bolts backwards from the outside, so make sure you have your lefty loosy correct.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
1 Post
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by Subdriver
First time off is a PITA. I broke mine loose without an impact wrench. Get a longer breaker bar. Likely the stock thread sealant is adding to the torque you need to break them loose. Good luck.
1 Post
Sometimes some good hard blows from a hammer flat on the head of a bolt will help jar it loose. You can also use a good quality box end wrench and hammer. Put the box end wrench on the bolt and hit the wrench with a hammer. Watch those fingers! If your using an air impact wrench you can normally get a little extra torque by using a little air tool oil in the impact. Most impacts will have the most torque the first few seconds after you pull the trigger. So a bunch of short 1-2 seconds bursts with 1-2 seconds off time in between will allow air to refill the hose back to max pressure. Also make sure you air pressure is at max. Wait will the compress fills and shuts off before hammering. When the compressor starts again wait till it refills. If nothing else works a little heat will also help, but be careful of what and how much your heating. You will want to heat the part that the bolts thread into, not the bolt itself.
Good luck!
Good luck!
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Skip the impact wrench! Use a quality box end wrench or a six point 1/2 drive breaker bar and a cheater bar! It will come off!
Please let us know how it turns out!
You got the right idea using penetrating oil, like WD40 or Liquid Wrench. I agree that a 6-point socket with a long ½ drive breaker bar & a cheater pipe should do the trick. If it’s real stubborn, try heating the head of the bolt with a torch (not melting or color changing hot) and strike the head with a hammer. This may knock some rust loose. Make sure you’re going counter-clockwise as you face the bolt.
PS: If you decide to heat the bolt head…. Make sure all flammable items are far away and excess the penetrating oil is wiped off.
Good Luck
Good Luck
Received 3,812 Likes
the torque isnt the problem, it is the red loctite.
Better Fit?
________________________________________ ____________________
[diynoob]Thanks for the tip, will give that a try.
I double checked the lefty-loosey, and am turning in the right direction....
Righty-Tighty......Lefty-Loosey. I think a 6 sided 13/16 socket fits better than a 21mm. Leverage, lots of leverage. If you are going to use the original bolts, clean the threads good and use Loctite again. Good luck
I had a heck of a time. My Kobalt 1/2" breaker bar seemed to have too much "flex". I went to a standard 1/2" ratchet and found the BIG rubber mallet my wife had lost. A couple of whacks latter and the bolt came loose. I was not successful in figuring out how to fit a torque wrench to the rear bolt to tighten.
Originally Posted by 12stepvette
Leverage is your friend!!
Good Luck!
